Hi,
I am using ros2 galactic installed from ros-testing repository
I implemented the keepout_filter as described in the official doc, the problem is that the forbidden areas are not inflated which results that the robot cannot avoid them. as seen in the image below.
I am wondering how can I set the inflation to danger areas as shown in stevemacenski's demo. Thanks in advance
Then:
Originally posted by Youssef_Lah on ROS Answers with karma: 195 on 2021-06-05
