Hi,
I'm currently trying to use the ros2 branch of MTC (MoveIt Task Constructor) to plan a circular motion to open a door. I know that it's possible to use the MoveTo
or MoveRelative
stages to make an arm rotate around the TCP frame by just specifying the desired goal orientation in a PoseStamped message (MoveTo
) or angular rotation in a TwistStamped message (MoveRelative
) - as shown in the Cartesian demo code.
So what I'm thinking of doing is adding a fixed frame in the robot URDF (let's call it the door_hinge_frame
) that is a child of one of the robot's links (not necessarily the TCP frame though). The door_hinge_frame
would be located at the physical joint of the door when the TCP is in the desired 'opening' pose. Then, by just specifying the MoveTo
or MoveRelative
message frame_id to the door_hinge_frame
, and specifying the goal pose to 90 degrees, a circular motion should be planned that opens the door.
So a few questions:
- Is this the correct way to perform this motion or is there an easier way? If so, what would that way be?
- While trying to test this approach out, the resulting motion via MTC is not the one that I expected. Instead of performing a circular motion around the
door_hinge_frame
, the arm still tries to rotate around the TCP frame. I've also tried to set the stage IK frame (viastage->setIKFrame()
) to thedoor_hinge_frame
, but that results in non-circular trajectories around the hinge joint. - In the above example, the TCP frame should move as shown in the left-hand part of the image below. But let's say I want the desired motion to be more like the right-hand part. How would I achieve that?
If I was using the C++ MoveGroupInterace API, I could achieve this by sending a static transform to the TF tree of where the door hinge frame is located relative to a world
frame (in which case, I'd just delete the door_hinge_frame
in the robot URDF). Then I could create 90 or so waypoints that define the pose of the TCP relative to the door hinge frame such that the orientation of the TCP is as shown in the right-hand part of the image. Next, I could call the computeCartesianPath
function with the waypoints and generate the trajectory. However, the CartesianPath class in MTC does not include a 'plan' function that allows passing in waypoints. What I could do instead is just create a Serial
container of MoveTo stages in which I define the 90 or so waypoints. However, then the arm would accelerate/decelerate to each of the 90 waypoints instead of creating one trajectory where the arm would would only accelerate/decelerate once...
Any help with answering these questions would be much appreciated! Note that I'm working in a Docker container running Ubuntu 20.04 and ROS Galactic (I've also seen this issue in a Docker container running Ubuntu 22.04 and ROS Humble). My host laptop runs Ubuntu 18.04.
Originally posted by swiz23 on ROS Answers with karma: 86 on 2022-05-03
Comment by fvd on 2022-08-13:
This answer discusses the "conventional" waypoint method you described. Note that the Pilz industrial planner offers a CIRC option. You could extend MTC with a CircularPath
class and use it.
This question is quite broad, so it might not get a proper response. Please self-answer when you find a satisfactory solution to your problem.
