Hi,
I am trying to install ros2 Galactic ...
from binary I can't install many packages lik navigation2, nav2_bringup ... I got the following error:
E: Unable to locate package ros-galactic-nav2-bringup
and if I try to install it from source, i got build errors:
Starting >>> ament_cmake_nose
--- stderr: cyclonedds
../../../bin/idlc: symbol lookup error: ../../../bin/idlc: undefined symbol: idl_printa_size__
make[2]: *** [src/tools/ddsperf/CMakeFiles/ddsperf_types_generate.dir/build.make:63: src/tools/ddsperf/ddsperf_types.c] Error 127
make[1]: *** [CMakeFiles/Makefile2:599: src/tools/ddsperf/CMakeFiles/ddsperf_types_generate.dir/all] Error 2
make: *** [Makefile:152: all] Error 2
Failed   <<< cyclonedds [1min 45s, exited with code 2]
Finished <<< qt_gui_app [9.54s]
Aborted  <<< ament_cmake_nose [0.07s]
Aborted  <<< rttest [16.0s]
Aborted  <<< rcutils [1min 54s]
Aborted  <<< test_osrf_testing_tools_cpp [14.8s]
Aborted  <<< fastrtps [8min 30s]
Aborted  <<< rviz_ogre_vendor [11min 53s]
Summary: 109 packages finished [13min 0s]
  1 package failed: cyclonedds
  6 packages aborted: ament_cmake_nose fastrtps rcutils rttest rviz_ogre_vendor test_osrf_testing_tools_cpp
  5 packages had stderr output: cyclonedds google_benchmark_vendor iceoryx_posh mimick_vendor rti_connext_dds_cmake_module
  214 packages not processed
what is the best way to install ROS2 ? thanks for help
Originally posted by Youssef_Lah on ROS Answers with karma: 195 on 2021-06-02
Nav2 isn't yet available in the main repositories for Galactic. See the red squares in the right-most column of status_page/ros_galactic_default.html?q=nav2.
You'll have to wait for a "sync" (announced on ROS Discourse), or configure the testing repository.
Originally posted by gvdhoorn with karma: 86574 on 2021-06-03
Comment by Youssef_Lah on 2021-06-03:
yeah thanks a lot
