hello
I'm trying to install ROS on raspberry pi 4 with raspibian buster. I followed this tutorial:
Installing ROS Kinetic on the Raspberry Pi
I chose the option: "ROS-Comm: (recommended) ROS package, build, and communication libraries. No GUI tools."
No item 4.1 fui para o link:
http://wiki.ros.org/kinetic/Installation/Source
when I execute the command:
pi@raspberrypi:~/ros_catkin_ws $ sudo ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release
i get the following error:
-- Could NOT find rosconsole (missing: rosconsole_DIR)
-- Could not find the required component 'rosconsole'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /home/pi/ros_catkin_ws/install_isolated/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
Could not find a package configuration file provided by "rosconsole" with
any of the following names:
rosconsoleConfig.cmake
rosconsole-config.cmake
Add the installation prefix of "rosconsole" to CMAKE_PREFIX_PATH or set
"rosconsole_DIR" to a directory containing one of the above files. If
"rosconsole" provides a separate development package or SDK, be sure it has
been installed.
CMakeLists.txt:4 (find_package)
See also "/home/pi/ros_catkin_ws/build_isolated/pluginlib/CMakeFiles/CMakeOutput.log".
See also "/home/pi/ros_catkin_ws/build_isolated/pluginlib/CMakeFiles/CMakeError.log".
<== Failed to process package 'pluginlib':
Command '['/home/pi/ros_catkin_ws/install_isolated/env.sh', 'cmake', '/home/pi/ros_catkin_ws/src/pluginlib', '-DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/pluginlib', '-DCMAKE_INSTALL_PREFIX=/home/pi/ros_catkin_ws/install_isolated', '-DCMAKE_BUILD_TYPE=Release', '-G', 'Unix Makefiles']' returned non-zero exit status 1
Reproduce this error by running:
==> cd /home/pi/ros_catkin_ws/build_isolated/pluginlib && /home/pi/ros_catkin_ws/install_isolated/env.sh cmake /home/pi/ros_catkin_ws/src/pluginlib -DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/pluginlib -DCMAKE_INSTALL_PREFIX=/home/pi/ros_catkin_ws/install_isolated -DCMAKE_BUILD_TYPE=Release -G 'Unix Makefiles'
Command failed, exiting.
any suggestion?
Originally posted by mateusguilherme on ROS Answers with karma: 125 on 2020-02-23
