I am experiencing very slow builds (and I have been for a while) using catkin_make building the ROS navigation stack. I have tried -DCMAKE_BUILD_TYPE=Release, --use-ninga, ccache, etc but the problem still persists. Specifically, clean builds sometimes take me over an hour on a modern machine (i7 w/ 8GB RAM).
The build process proceeds rather quickly until it seems to stall out at 100%. A quick htop reveals that the culprit is a couple of linking threads that are taking 100% CPU and often are costmap_2d or trajectory planner related.
Has anyone seen this before or have any insight on how to fix this?
Additional Information
OS: Ubuntu 16.04.5 LTS
gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
cmake version 3.5.1
ROS Version: Kinetic
ROS Install: ROS installed from .debs (desktop-full) and upgraded w/ apt
Steps to reproduce:
mkdir -p ~/test/src
cd ~/test/src
catkin_init_workspace
git clone https://github.com/ros-planning/navigation.git
git checkout kinetic-devel
cd ..
catkin_make
... wait ...
Total Build Time: 22.5 min
The build got to 100% after <5min with the last message printed ... `
[100%] Built target move_base_node
Then 15 min later ...
[100%] Built target costmap_2d_cloud
[100%] Built target costmap_2d_markers
Base path: /home/patrick/test
Source space: /home/patrick/test/src
Build space: /home/patrick/test/build
Devel space: /home/patrick/test/devel
Install space: /home/patrick/test/install
#### Running command: "cmake /home/patrick/test/src -DCATKIN_DEVEL_PREFIX=/home/patrick/test/devel -DCMAKE_INSTALL_PREFIX=/home/patrick/test/install -G Unix Makefiles" in "/home/patrick/test/build"
#### Running command: "make -j6 -l6" in "/home/patrick/test/build"
The full output of catkin_make is available here ... https://pastebin.com/ZkFUqU2s
Additional Information - Second Round
Memory consumption during the first 5 minutes of the build ...
patrick@patrick:~/test$ free -mh
              total        used        free      shared  buff/cache   available
Mem:           7.2G        4.1G        222M        1.1G        2.9G        1.5G
Swap:          7.4G        3.2G        4.3G
After reaching the 100% ...
Mem:           7.2G        4.6G        180M        1.2G        2.5G        1.0G
Swap:          7.4G        3.2G        4.2G
It looks like there should be plenty of free memory right?
Also, here are the processes that are "stalling" out in the second 15min of the build ... https://pastebin.com/CDb2qLQs
Specifically, the /usr/bin/ld threads (there are 2, costmap_2d_cloud and costmap_2d_markers) which are taking 100% CPU
Originally posted by baronep on ROS Answers with karma: 106 on 2018-09-12
Comment by gvdhoorn on 2018-09-13:
Please add some information about your system: which OS is this, which version, how did you install ROS (.debs or completely from source), which and what version of compiler do you have installed, CMake version and what exactly you are building (ie: pkgs).
Comment by baronep on 2018-09-13:
Added additional information in the post above
Comment by David Lu on 2018-09-13:
What does your memory usage look like during that time?
Added additional information above
Comment by baronep on 2018-09-14:
Just an observation, if I comment out the costmap_2d_cloud and costmap_2d_markers targets in the CMakelists.txt, my build reduces from >20min to ~3min. What about these 2 targets would make them have such a dramatic impact? voxel_grid?
I've replicated your problem. It's hanging on the linking step, but you can fix it by adding ${catkin_LIBRARIES} to the target_link_libraries command for costmap-2d_cloud and markers. Not sure why yet, but I'm going to investigate and make a PR.
Originally posted by David Lu with karma: 10932 on 2018-09-19
Comment by David Lu on 2018-10-12:
https://github.com/ros-planning/navigation/pull/800
