Hello there,
I have been fighting for some time with CMakeLists trying to compile a ROS 2 Eloquent package (bar) depending on a pure cmake package (foo) using colcon but I get the following error:
<...>/bar.hpp:5:10: fatal error: foo/foo.hpp: No such file or directory
#include "foo/foo.hpp"
I've made a minimal repo showing my problem here: https://github.com/MarcTestier/ros2_cmake_test.
The install folder of the cmake package (foo) seems somewhat normal though, its folder tree looks like this:
install/foo/
├── include
│ └── foo
│ ├── foo.hpp
│ └── foo_export.h
├── lib
│ └── libfoo.so
└── share
├── colcon-core
│ └── packages
│ └── foo
└── foo
├── cmake
│ ├── fooConfig.cmake
│ ├── fooConfigVersion.cmake
│ ├── fooTargets-noconfig.cmake
│ └── fooTargets.cmake
├── hook
│ ├── cmake_prefix_path.dsv
│ ├── cmake_prefix_path.ps1
│ ├── cmake_prefix_path.sh
│ ├── ld_library_path_lib.dsv
│ ├── ld_library_path_lib.ps1
│ ├── ld_library_path_lib.sh
│ ├── pkg_config_path.dsv
│ ├── pkg_config_path.ps1
│ ├── pkg_config_path.sh
│ ├── pkg_config_path_multiarch.dsv
│ ├── pkg_config_path_multiarch.ps1
│ └── pkg_config_path_multiarch.sh
├── package.bash
├── package.dsv
├── package.ps1
├── package.sh
└── package.zsh
It seems like the ROS 2 package (bar) has trouble finding the cmake package (foo) library and headers but find_package(foo)
works.
I found an ugly solution (available in the repo here) which consists of 2 steps:
1.Manually add the include directory
get_filename_component(INSTALL_DIR ${CMAKE_INSTALL_PREFIX} DIRECTORY)
include_directories(${INSTALL_DIR}/foo/include/)
If I only perform step 1, I can find the header files but I get an error: /usr/bin/ld: cannot find -lfoo
which I guess means that even though I do the following:
target_link_libraries(Bar foo)
Bar still can't properly find the foo library.
2.If on top of the first step I link directly against the .so file:
target_link_libraries(Bar "${INSTALL_DIR}/foo/lib/libfoo.so")
Now the packages can compile but the solution seems a bit ugly.
I'm out of idea and I can't tell if the problem comes from a pure cmake problem, colcon moving/linking stuff around or anything else so any suggestions are welcomed, thanks.
Originally posted by Marc Testier on ROS Answers with karma: 203 on 2020-02-18
