Hi
I am new to colcon and ros in general, so please forgive my newby question. I completed the all the beginner ROS2 tutorials and all went well.
Now I am trying to compile some third party code into a library (feetech_driver) to use in another ROS package (ft_joint). I have been able to compile the library and the output files are copied to
ros_ws/install/feetech_driver
      |-include
      |-lib
      |-share
All the header files are in the ros_ws/install/feetech_driver/include/feetech_driver directory
My other ROS package (ft_joint) that is trying to use this library package cannot find the required header file, I am including it like so,
#include "feetech_driver/SCSCL.h"
As part of my ft_joint package I also include files from the tutorial_interfaces tutorial and I can include those without error, like so,
#include "tutorial_interfaces/msg/num.hpp"
My CMakeList.txt has a find_package for both packages, like so
find_package(tutorial_interfaces REQUIRED)
find_package(feetech_driver REQUIRED)
The error that I get when I run
colcon build --packages-select ft_joint
is
/home/stewart/ros/dev_ws/src/ft_joint/src/joint_node.cpp:6:10: fatal error: feetech_driver/SCSCL.h: No such file or directory
    6 | #include "feetech_driver/SCSCL.h"
Any suggestions would be greatly appreciated.
Thanks Stew
Originally posted by stewart menday on ROS Answers with karma: 11 on 2020-10-28
Hello,
In this repo you will find some basic ROS 2 examples. For example you should have a look to this CMakeLists.txt.
You should find_package:
find_package(rclcpp REQUIRED)
And then if it's a ROS 2 dependency, you should link against it
ament_target_dependencies(<you target name> rclcpp )
If it's not a ROS 2 dependency, then you should use the CMake functions. Like target_link_libraries or target_include_directories.
Regards
Originally posted by ahcorde with karma: 421 on 2020-10-29
Comment by stewart menday on 2020-10-29:
Thank you for your answer. I have been able to get it to work as follows, In my CMakeList.txt file I originally had
add_executable(joint_node src/joint_node.cpp)
ament_target_dependencies(joint_node rclcpp tutorial_interfaces feetech_driver ft_message)
Which didn't work, it wouldn't find the headers or the feetech_driver library file. After changing CMakeList.txt to
#don't know why the find_package(feetech_driver REQUIRED) above isn't sufficient, but need the 2 lines below
find_library(DRIVER ftd_scscl)
find_path(HEADERS NAMES SCSCL.h SCSerial.h SCServo.h SCS.h HINTS ${AMENT_PREFIX_PATH})
target_include_directories(joint_node PUBLIC $<BUILD_INTERFACE:${HEADERS}>)
target_link_libraries(joint_node ${DRIVER})
It now works :)
