Ubuntu 18.04 running Dashing on hash bafddbdb of master
The example from the Colcon Tutorial does not build.
https://index.ros.org/doc/ros2/Tutorials/Colcon-Tutorial/
I kept getting errors like this from colcon :
Could not find a package configuration file provided by "example_interfaces" with any of the following names:
example_interfacesConfig.cmake
example_interfaces-config.cmake_
I grepped through the commit logs of this repo and 64128033 seemed like the cause - so I cloned https://github.com/ros2/example_interfaces into my src directory such that my filesystem was like this
---- src
-------- examples
-------- example_interfaces
and Cmake stopped complaining about an unknown dependency.
After that I got a build error on master, went to the dashing branch and got farther, but I kept getting more colcon errors, and after cloning the following three repos into my src directory colcon built for me
https://github.com/ros2/rclcpp https://github.com/ros2/rcl_interfaces https://github.com/ros2/test_interface_files
my final directory structure looked like this: .
---- src
-------- examples
-------- rcl_interfaces
-------- test_interface_files
Did I miss a step in my install or is that tutorial lacking these steps?
Thanks
Originally posted by johnconn on ROS Answers with karma: 553 on 2019-06-30
It looks like you have not sourced the ROS2 SDK before building your new workspace: https://index.ros.org/doc/ros2/Tutorials/Colcon-Tutorial/#source-an-underlay
cd <path_to_ros2_ws>
source install/setup.sh
For the following errors, I think that you may have mixed different versions of SDK and examples repositories. Ensure that both of them are up to date to the distribution that you are using (Dashing).
Originally posted by alsora with karma: 1322 on 2019-07-02
Comment by phil123456 on 2023-07-27:
I have the same issue with humble
