Hello,
I want use a library called libnpsauv.a in my package. Although I know that I have to use target_link_libraries i don't know how to use it properly.
I tried:
target_link_libraries(${PROJECT_NAME} npsauv)
But then I got that when rosmaking:
{------------------------------------------------------------------------------- mkdir -p bin cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=rospack find rosbuild/rostoolchain.cmake .. [rosbuild] Building package npsauv_simulation [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/roslisp/cmake/roslisp.cmake [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/rospy/cmake/rospy.cmake [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/cpp/roscpp/cmake/roscpp.cmake CMake Error at CMakeLists.txt:26 (target_link_libraries): Cannot specify link libraries for target "npsauv_simulation" which is not built by this project.
Note: I copied the library into the lib package folder.
Originally posted by ffusion on ROS Answers with karma: 13 on 2012-03-26
You have to specify the name of the executable which needs your library as target:
 target_link_libraries(my_node npsauv)
(In your case CMake complains because there is no target named ${PROJECT_NAME}.)
Originally posted by Stephan with karma: 1924 on 2012-03-26
Post score: 4
