I am working with Autoware 1.12.0 (source build) on Ubuntu 18.04 (Melodic). The GUI glitch I am facing is that the window doesn't clean when UI elements redraw, so I end up with text writing over text every time I switch from one tab to the next in the runtime manager. The terminal output is: GtK-WARNING **: Negative content height while allocating gadget (node entry, owner GtKentry)
Thank you
Originally posted by ArdashirB on ROS Answers with karma: 13 on 2019-07-17
