From the documentation (http://docs.ros.org/melodic/api/rostime/html/classros_1_1Time.html#a84cd12a499c70fb3eefce89cda2b6113), ros::Time::isValid returns "whether or not the current time is valid. Time is valid if it is non-zero".
However, a trivial example is enough to show that the implementation does not do this:
#include <ros/ros.h>
int main(int argc, char** argv) {
    ros::init(argc, argv, "rostime_example");
    ros::NodeHandle n;
    // default construct a time
    ros::Time t;
    ROS_WARN_STREAM("time value: " <<t.toSec());
    ROS_WARN_STREAM("time valid: " <<t.isValid());
    return 0;
The output is:
ivaughn@ros-pc:~/test_ws$ rosrun rostime_example node
[ WARN] [1561399516.961348750]: time value: 0
[ WARN] [1561399516.961420491]: time valid: 1
Any idea what's going on here? Is this just a bug in ROS 1, or am I misunderstanding how this function is expected to behave.
We're kind of curious, behavior that does something different when a timestamp is invalid is often safety-critical. Thanks!
Originally posted by ivaughn_whoi on ROS Answers with karma: 13 on 2019-06-24
I believe this is due to a misunderstanding of the comment on isValid().
The documentation indeed states (here):
Returns whether or not the current time is valid. Time is valid if it is non-zero.
But "the [..] time" it refers to is not the Time instance, but "the time", as in: the global ROS time.
A ROS node can use different methods to retrieve the "current time": it can use walltime, a simulation time or something else. The "valid" here essentially returns true whenever one of those sources have been selected and has been initialised properly.
0 is chosen as a sentinel value to detect when that is not the case (as it's assumed that 0 is just not a valid value for any source of time (whether that is correct is something else)).
It's slightly confusing that a ros::Time instance can also have a 0 value and that ros::Time::isValid() is a static method of the ros::Time class.
In the code that you show:
isValid() will return true as soon as you call ros::init(..) (as one of its duties is to initialise the time subsystem).
We can also take a look at the sources (from here):
bool Time::isValid()
  return (!g_use_sim_time) || !g_sim_time.isZero();
This essentially tells us that "time" is considered "valid" if either we're not using simulation time, or, if simulation time is being used, it's != 0.
The g_ prefixes tell us that this static method is checking globals, not ros::Time member variables.
Edit: perhaps a nice contribution would be to improve the documentation of this method and to remove the ambiguity.
Originally posted by gvdhoorn with karma: 86574 on 2019-06-24
Comment by gvdhoorn on 2019-06-24:
And this is not directed at you, but:
Is this just a bug in ROS 1, [..]
I like how posters here often insert these sort of statements almost casually in their questions.
Comment by ivaughn_whoi on 2019-06-24:
Yeah, I'd like to make sure I correctly understand what's going on before claiming its a bug. WIth ROS its more likely to be a documentation issue than anything else.
Pull request: https://github.com/ros/roscpp_core/pull/109
