Hi,
I came up across remote mapping and RTABmap provides this launch file:
<launch>
<include file="$(find freenect_launch)/launch/freenect.launch">
<arg name="depth_registration" value="True" />
</include>
<arg name="rate" default="5"/>
<arg name="approx_sync" default="true" /> <!-- true for freenect driver -->
<!-- Use same nodelet used by Freenect/OpenNI -->
<group ns="camera">
<node pkg="nodelet" type="nodelet" name="data_throttle" args="load rtabmap_ros/rgbd_sync camera_nodelet_manager" output="screen">
<param name="compressed_rate" type="double" value="$(arg rate)"/>
<param name="approx_sync" type="bool" value="$(arg approx_sync)"/>
<remap from="rgb/image" to="rgb/image_rect_color"/>
<remap from="depth/image" to="depth_registered/image_raw"/>
<remap from="rgb/camera_info" to="rgb/camera_info"/>
<remap from="rgbd_image" to="rgbd_image"/>
</node>
</group>
</launch>
What is the camera_nodelet_manager and how can I supply it? For example, if I use ZED camera they supply with the camera_manager: https://github.com/stereolabs/zed-ros-wrapper/blob/master/zed_wrapper/launch/zed_camera_nodelet.launch
But how exactly can I use it?
Originally posted by EdwardNur on ROS Answers with karma: 115 on 2019-04-01
Comment by matlabbe on 2019-04-03:
See this page: https://github.com/stereolabs/zed-ros-wrapper/tree/master/examples/zed_nodelet_example, showing how they start the nodelet manager. If you use the zed launch version without nodelet, launch rgbd_sync as a stanaldone nodelet like this :
<node pkg="nodelet" type="nodelet" name="data_throttle" args="standalone rtabmap_ros/rgbd_sync" output="screen">
