Hello everyone,
I started the tutorial about rosjava services recently. I've been following all the steps until I got to the final one where I need to execute rosrun in order to run the server and the client.
The problem I've found is that rosrun can't find org.ros.RosRun. I've sourced rosjava environment as well as executing roscore before attempting to run the server and the client. However, it is possible to execute the server and the client if you do it outside rosrun e.g. typing in the terminal
./build/install/client_server/bin/client_server org.ros.rosjava_tutorial_services.Client
Also, I've taken a look at previous topics and I've found a similar behaviour among the questions, but I didn't find a solution suitable for my problem. Some examples can be found here and here
I use Ubuntu 16.04 as well as ROS Kinetic, installing rosjava from sources. I've also tried installing rosjava from apt packages but I've the same results.
Is it a common problem? Am I doing something wrong?
Thanks for the help in advance
Originally posted by anonymous40337 on ROS Answers with karma: 16 on 2019-03-05
