Hey everyone.
I'm a complete newbie in ROS and am attempting to create a simple publishing/subscribing image platform. Some ROS tutorials regarding this issue use a deprecated protocol (CvBridge) so I'm stuck.
Here is what I have so far:
Image server (adapted from image_transfer tutorial (can't post links)):
int main(int argc, char** argv)
  ros::init(argc, argv, "image_publisher");
  ros::NodeHandle nh;
  image_transport::ImageTransport it(nh);
  cv_bridge::CvImagePtr cv_ptr(new cv_bridge::CvImage);
  cv_ptr->image = cv::imread("socio_32.jpg",CV_LOAD_IMAGE_COLOR);
  image_transport::Publisher pub = it.advertise("/topic_imgtransport", 1);
  sensor_msgs::ImagePtr msg = cv_ptr->toImageMsg();
  ros::Rate loop_rate(5);
  while (nh.ok())
    pub.publish(msg);
    ros::spinOnce();
    loop_rate.sleep();
And the Image Client (taken from UsingCvBridgeToConvertBetweenROSImagesAndOpenCVImages):
class ImageConverter
  ros::NodeHandle nh_;
  image_transport::ImageTransport it_;
  image_transport::Subscriber image_sub_;
  image_transport::Publisher image_pub_;
public:
  ImageConverter()
    : it_(nh_)
    image_pub_ = it_.advertise("out", 1);
    image_sub_ = it_.subscribe("/topic_imgtransport", 1, &ImageConverter::imageCb, this);
    cv::namedWindow(WINDOW);
  ~ImageConverter()
    cv::destroyWindow(WINDOW);
  void imageCb(const sensor_msgs::ImageConstPtr& msg)
    cout<<"Hello callback"<<endl;
    cv_bridge::CvImagePtr cv_ptr;
    try
      cv_ptr = cv_bridge::toCvCopy(msg, enc::BGR8);
    catch (cv_bridge::Exception& e)
      ROS_ERROR("cv_bridge exception: %s", e.what());
      return;
    if (cv_ptr->image.rows > 60 && cv_ptr->image.cols > 60)
      cv::circle(cv_ptr->image, cv::Point(50, 50), 10, CV_RGB(255,0,0));
    cv::imshow(WINDOW, cv_ptr->image);
    cv::waitKey(3);
    image_pub_.publish(cv_ptr->toImageMsg());
  ros::init(argc, argv, "image_converter");
  ImageConverter ic;
  ros::spin();
  return 0;
This doesn't work. Here is the output when I run the client and then the server:
Hello callback
[ERROR] [1362578421.357583807]: cv_bridge exception: Unrecognized image encoding []
In the cv_ptr = cv_bridge::toCvCopy(msg, enc::BGR8); line I tried several encoding types, namely "bgr8", "mono8" (as the documentation actually states) and the exception remains the same.
I can visualize the image in the server side, and rostopic echos the correct data about the image.
So obviously the problem is in the way I am receiving the image.
Any thoughts?
Originally posted by Median on ROS Answers with karma: 23 on 2013-03-06
Comment by Thomas on 2013-09-30:
The problem is that it seems like the message you are sending does not fill the encoding field. Therefore, cv_bridge cannot know how to interpret the image. Can you run rostopic echo /topic_imgtransport --noarr -n 1 and post the result in your question?
In the code on your image publisher side you need to fill the encoding. After
add a line like:
cv_ptr->encoding = "bgr8";
Note that opencv's highgui (e. g. imread, imwrite) functions by default assume BGR8 color space.
Originally posted by Wolf with karma: 7555 on 2015-03-24
