I want to make parameter server with rosjava. But I can not. As far as I've looked up, I can not find the latest information on parameter server anywhere. That's why I want you to help me
I want to use AddTwoInts. However, when executing catkin_make, it says that the package of AddTwolnts can not be found. I guessed I had to edit build.gradle. But I do not know how to edit it
che License, Version 2.0 (the "License"); you may not
 * use this file except in compliance with the License. You may obtain a copy of
 * the License at
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
 * License for the specific language governing permissions and limitations under
 * the License.
package com.github.rosjava.test;
import org.apache.commons.logging.Log;
import org.ros.node.Node;
import org.ros.node.NodeMain;
import org.ros.node.service.ServiceClient;
import org.ros.node.service.ServiceResponseListener;
import org.ros.exception.RemoteException;
import org.ros.service.test_ros.AddTwoInts;
import org.ros.namespace.GraphName;
// add for parameter
import org.ros.node.parameter.ParameterTree;
 * @author OTL
public class Parameters implements NodeMain {
  @Override
  public GraphName getDefaultNodeName() {
    return new GraphName("rosjava_tutorial_service/client");
  @Override
  public void onStart(Node node) {
    try {
      ServiceClient<AddTwoInts.Request, AddTwoInts.Response> client =
          node.newServiceClient("/add_two_ints", "test_ros/AddTwoInts");
      Thread.sleep(100);
      AddTwoInts.Request srv = new AddTwoInts.Request();
      ParameterTree params = node.newParameterTree();
      srv.a = params.getInteger("/a", 1);
      srv.b = params.getInteger("/b", 5);
      client.call(srv, new ServiceResponseListener<AddTwoInts.Response>() {
            @Override
                public void onSuccess(AddTwoInts.Response res) {
              log.info("call service success! " + res.sum);
            @Override
                public void onFailure(RemoteException arg) {
              log.info("call service fail");
    } catch (Exception e) {
      if (node != null) {
        node.getLog().fatal(e);
      } else {
        e.printStackTrace();
  @Override
  public void onShutdown(Node node) {
  @Override
  public void onShutdownComplete(Node node) {
Originally posted by hamada on ROS Answers with karma: 43 on 2018-07-25
Hi @hamada! First of all, take a look into https://wiki.ros.org/rosjava; that's the entry point for the most up-to-date tutorials (see Kinetic version).
Regarding this question in particular, I see two different issues:
Originally posted by jubeira with karma: 1054 on 2018-08-01
