Hello,
I would like to visualize some 2d objects using lines or bounding boxes in a 2d image in RVIZ. So far I was not able to find a way. I am suspecting that this might not be supported by RVIZ. But since I only started using ROS it is also likely that I was just looking at the wrong place.
Here is what I found out so far:
- I can visualize things in 3D using markers.
- I can visualize an image using the display type Image.
- I can also visualize an image using the display type camera, and I think if there is correct calibration information, the 3d markers get projected in that image.
But is there a way to directly draw something like the markers into a 2d image?
Originally posted by sietschie on ROS Answers with karma: 11 on 2018-07-26
