I've commanded the robot to go to the green arrow position/rotation, so it went there and started rotating CCW until it got near the upper wall, then it got stuck in that position. The question is why it don't go a bit forward so it can complete the rotation? Which parameters can be changed so that it better behave in situations like that?
image description
Update: It keeps writing in the logs:
[ INFO] [1501263591.230230037]: Got new plan [ WARN] [1501263591.260831641]: Invalid Trajectory 0.000000, 0.000000, 0.150000, cost: -6.000000 [ WARN] [1501263591.260927725]: Rotation cmd in collision [ INFO] [1501263591.260981225]: Error when rotating.
and after some seconds:
[ERROR] [1501263591.331646239]: Aborting because a valid control could not be found. Even after executing all recovery behaviors
Currently we have recovery_behavior_enabled = true and clearing_rotation_allowed = false
Originally posted by Vitor on ROS Answers with karma: 41 on 2017-07-27
Comment by jayess on 2017-07-28:
What's the output at the terminal?
Comment by Vitor on 2017-07-28:
@jayess I've updated the question with console output
I believe it's because you have the clearing_rotation_allowed parameter set to false. It won't rotate to clear the cost map and replan, it'll just give up like you're seeing.
From the wiki, the clearing_rotation_allowed parameter
Determines whether or not the robot will attempt an in-place rotation when attempting to clear out space. Note: This parameter is only used when the default recovery behaviors are in use, meaning the user has not set the recovery_behaviors parameter to anything custom.
Originally posted by jayess with karma: 6155 on 2017-07-28
Comment by Vitor on 2017-07-31:
I'll try to enable that, but that behavior has given me problems in the past (like colliding with walls). However, I can't understand why it can't finish the move without resorting to the recovery behaviors, as it would be a simple movement to get out of there
