Hi, I am new to ros. we are trying to interface the dynamixel Pro-42 series actuator to our hardware. we are following steps mentioned in tutorial "http://wiki.ros.org/dynamixel_controllers/Tutorials/ConnectingToDynamixelBus"
the problem is when we give command
roslaunch my_dynamixel_tutorial controller_manager.launch
on console it prints two messages that are:
load_parameter : Last successfully loaded parameter (/dev/ttyUSB0)
"cannot marshal None unless allow_none is enabled"
File "/usr/lib/python2.7/xmlrpclib.py", line 664, in dump_nil
raise TypeError, "cannot marshal None unless allow_none is enabled
"TypeError: cannot marshal None unless allow_none is enabled
How do i solve this issue..
<!-- -*- mode: XML -*- -->
<launch>
<node name="dynamixel_manager" pkg="dynamixel_controllers" type="controller_manager.py" required="true" output="screen">
<rosparam>
namespace: dxl_manager
serial_ports:
pan_tilt_port:
port_name: "/dev/ttyUSB0"
baud_rate: 57600
min_motor_id: 1
max_motor_id: 25
update_rate: 20
</rosparam>
</node>
</launch>
thanks in advance..
Originally posted by pratikshriniwar on ROS Answers with karma: 1 on 2017-07-19
