I am trying to transfer a camera(non-uvc) stream program to ros platform.
I've already got the camera driver running
and Makefile is like this:
g++ main.cpp -o test_gui -g -I /usr/local/include -L /usr/local/lib -D_LIN -D_DEBUG -L../lib/x64 -I../include -lASICamera -lpthread -lusb -DGLIBC_20 -m64 -lrt -I/opt
Now I want to do this in a ros node, so I write a node in which the CMakelists is like this:
include_directories( ${catkin_INCLUDE_DIRS} )
include_directories(/usr/local/include)
include_directories(/root/catkin_ws/src/asi_converter_real/include/asi_converter_real)
link_directories(/usr/local/lib)
link_libraries(pthread)
link_libraries(usb)
link_libraries(libASICamera.a)
link_libraries(libASICamera.so)
add_executable(asi_converter_real src/asi_converter_real.cpp)
target_link_libraries(asi_converter_real ${catkin_LIBRARIES})
And the Makefile line generated into /catkin_ws/build/***/ is like this:
/usr/bin/c++ CMakeFiles/asi_converter_real.dir/src/asi_converter_real.cpp.o -o /root/catkin_ws/devel/lib/asi_converter_real/asi_converter_real -rdynamic -L/usr/local/lib -lpthread -lusb -Wl,-Bstatic -lASICamera -Wl,-Bdynamic -lASICamera
But it seems that the system cannot find the dynamic libraries of libusb, coz' it reports
undefined reference to `libusb_set_configuration'
undefined reference to `libusb_claim_interface'
/usr/local/lib/libASICamera.a(ASI174MM.o): In function `WorkingFunc(void*)':
undefined reference to `libusb_bulk_transfer'
[1]Could anyone tell me how to solve this problem ?
[2]How to find the .a and .so of libusb in my computer ? (I am sure I have them, coz' I can pkg-config --cflags/--libs them)
[3]How could I explicitly link a dynamic library in ros CMakelists ? or just link_libraries(usb) is enough for both static and dynamic libriries ?
Originally posted by fromandto on ROS Answers with karma: 27 on 2014-11-25
You shouldn't link to both static and dynamic libraries. One or the other is sufficient.
In your case, instead of linking to libASICamera.a and libASICamera.so, you should just do:
link_libraries(ASICamera)
And cmake will find the appropriate static or dynamic library depending on how you're linking your executable.
Also note that if your libraries have undefined symbols the linking order matters - libraries with undefined symbols should be listed first, and the libraries which contain those symbols should be listed later.
Finally, the link_libraries() command is pretty heavy-handed; it will cause all of your executables to be linked against every library you specify. Use target_link_libraries() instead, and note that you can list multiple libraries in a single linking command.
Maybe try:
target_link_libraries(asi_converter_real ${catkin_LIBRARIES} pthread ASICamera usb)
Originally posted by ahendrix with karma: 47576 on 2014-11-25
Comment by fromandto on 2014-11-25:
thx very much, it's done.
