Dear List,
Since the last update of indigo (juli 2017) I am getting error messages in move_group with moveit.
For example with moveit-commander, after each "go up" or so, there are 4 lines with
[ERROR] [1499944106.195095905]: Found empty JointState message
Moveit seems to work however. It did NOT occur before the last update, and it also occurs in the kinetic version.
Anything I can do?
Regards, Sietse
Originally posted by Sietse on ROS Answers with karma: 168 on 2017-07-13
Comment by gvdhoorn on 2017-07-13:
NB: in order for errors to show up, you need to format them as preformatted text. Use the button with 101010
on it for that.
Comment by hvpandya on 2017-07-17:
+1 Observing same issue across three different robots in Kinetic, does not affect the operation for any of them.
