Hi,
I am trying to use MoveIt! to control a simulated robot in Gazebo, and am at a loss as to how to proceed. The only documentation / tutorial I can find on the subject is this one, which is 4 years old and works only for a specific robot, that comes with all the necessary controllers.
My understanding so far:
  • The MoveItSimpleControllerManager plugin should 'convert' MoveIt! executions to FollowJointTrajectory action calls. I have included the plugin in myrobot_moveit_controller_manager.launch (adapted from the demo.launch generated by the MoveIt! setup assistant) with:
      <!-- Set the param that trajectory_execution_manager needs to find the controller plugin -->
      <arg name="moveit_controller_manager" default="moveit_simple_controller_manager/MoveItSimpleControllerManager" />
      <param name="moveit_controller_manager" value="$(arg moveit_controller_manager)"/>
      <arg name="controller_manager_name" default="moveit_simple_controller_manager" />
      <param name="controller_manager_name" value="$(arg controller_manager_name)" />
      <arg name="use_controller_manager" default="true" />
      <param name="use_controller_manager" value="$(arg use_controller_manager)" />
      <!-- load controller_list -->
      <rosparam file="$(find myrobot_moveit_config)/config/controllers.yaml"/>
  • The joint_trajectory_controller from ros_controllers should implement the action server required for the FollowJointTrajectory calls, and actuate the joints in Gazebo accordingly via the libgazebo_ros_control plugin for Gazebo. I am trying to spawn the controller with:
      <node name="controller_spawner"
            pkg="controller_manager"
            type="spawner"
            respawn="false"
            output="screen"
            ns="/myrobot"
            args="joint_state_controller joint_trajectory_controller"/>
The problem:
When I run the above launch files as well as the Gazebo one (which also uploads the robot description to the param server), I get the following output in the MoveIt! terminal:
[FATAL] [1498731799.850090680, 16.100000000]: Parameter '~moveit_controller_manager' not specified. This is needed to identify the plugin to use for interacting with controllers. No paths can be executed.
I'm using ROS Indigo with Ubuntu 14.04.
Could some-one let me know if my overall understanding is flawed, and what might cause the above error message?
Thanks.
Update:
I fixed the above error message by putting the first set of XML tags inside the namespace of the move_group node, with:
<group ns="move_group"> ... </group>
Now the controller manager seems to be connected, but I get the following error messages. When I start the MoveIt! node:
[ERROR] [1498747248.394583362, 16.231000000]: MoveItSimpleControllerManager: Action client not connected: arm_r_controller/follow_joint_trajectory
And when I attempt to execute a trajectory:
[ERROR] [1498747328.213270503, 70.727000000]: Unable to identify any set of controllers that can actuate the specified joints: [ ... ]
It was my understanding that MoveItSimpleControllerManager was the 'action client' - is this wrong?
Originally posted by PhydeauxLeChien on ROS Answers with karma: 11 on 2017-06-29
Comment by PhydeauxLeChien on 2017-06-29:
If anyone could help with formatting XML in questions as well, that'd be great. The < param > tags don't seem to be displaying >.<
Comment by gvdhoorn on 2017-06-29:
Use the Preformatted Text button (the one with 101010 on it). Keep in mind that when formatting text that is part of a list, you'll have to increase indentation level (ie: prefix more spaces), as it's relative to the indentation level of the surrounding text.
Thanks - the list thing, that's what I was missing.
Comment by yyf on 2017-09-27:
Have you solved the problem:MoveItSimpleControllerManager: Action client not connected: arm_r_controller/follow_joint_trajectory? I have the same trouble.
The problem is that your MoveIt controller manager expects a ROS action at arm_r_controller/follow_joint_trajectory, but that does not exist. run rostopic list | grep goal and find the FollowTrajectoryAction that is setup with your gazebo ros_control plugin.
You can either change the topic in the gazebo configuration or in the controllers.yaml.
Originally posted by v4hn with karma: 2950 on 2017-09-27
