Hi, I'm trying to use the nmea_navsat_driver PKG to get GPS-Data from a ublox C94-M8P-3 Receiver. When running "rosrun nmea_navsat_driver nmea_serial_driver _port:=/dev/ttyACM0 _baud:=9600 " No data is published on the "/fix" topic. The nmea_serial_driver also does not print any output. I made sure my user is in the dialout group. And when using ucenter from ublox i can see that the GPS-Receiver is working.
Any ideas why it's not working?
Thank You!
Originally posted by blasalat on ROS Answers with karma: 51 on 2017-04-24
