I've been stuck on this for a while my problem is I cant access GPS data for a ublox node. I am connecting to a Raspberry pi 3 that is running a RPI 2 Snappy Image. I am connecting to the PI through a SSH on a ubuntu 14.04 laptop.
I am running the following command and getting this error: (updated output with correct port spelling)
    ubuntu@ubuntu:~$ roslaunch ublox_gps ublox_device.launch
... logging to /home/ubuntu/.ros/log/cefae814-d237-11e7-8ade-b827ebffc577/roslaunch-ubuntu-1799.log
Press Ctrl-C to interrupt
started roslaunch server http://192.168.2.55:35153/
SUMMARY
PARAMETERS
 * /rosdistro: kinetic
 * /rosversion: 1.12.7
 * /ublox_gps/debug: 1
 * /ublox_gps/device: /dev/ttyAMC0
 * /ublox_gps/dgnss_mode: 3
 * /ublox_gps/dr_limit: 0
 * /ublox_gps/dynamic_model: portable
 * /ublox_gps/enable_ppp: False
 * /ublox_gps/fix_mode: auto
 * /ublox_gps/frame_id: gps
 * /ublox_gps/gnss/beidou: False
 * /ublox_gps/gnss/glonass: True
 * /ublox_gps/gnss/qzss: False
 * /ublox_gps/inf/all: True
 * /ublox_gps/nav_rate: 4
 * /ublox_gps/publish/aid/hui: False
 * /ublox_gps/publish/all: True
 * /ublox_gps/publish/nav/posecef: False
 * /ublox_gps/rate: 4
 * /ublox_gps/save/device: 4
 * /ublox_gps/save/mask: 3103
 * /ublox_gps/uart1/baudrate: 19200
 * /ublox_gps/uart1/in: 32
 * /ublox_gps/uart1/out: 0
NODES
    ublox_gps (ublox_gps/ublox_gps)
auto-starting new master
process[master]: started with pid [1813]
setting /run_id to cefae814-d237-11e7-8ade-b827ebffc577
process[rosout-1]: started with pid [1826]
started core service [/rosout]
process[ublox_gps-2]: started with pid [1829]
terminate called after throwing an instance of 'std::runtime_error'
  what():  U-Blox: Could not open serial port :/dev/ttyAMC0 open: No such file or directory
[ublox_gps-2] process has died [pid 1829, exit code -6, cmd /home/ubuntu/catkin_ws/devel/lib/ublox_gps/ublox_gps __name:=ublox_gps __log:=/home/ubuntu/.ros/log/cefae814-d237-11e7-8ade-b827ebffc577/ublox_gps-2.log].
log file: /home/ubuntu/.ros/log/cefae814-d237-11e7-8ade-b827ebffc577/ublox_gps-2*.log
^C[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
I checked that the port was correct by using
cat /dev/ttyACM0
it outputted my GPS Data that I was looking for, I assumed that I was permission were off so I did the command
groups
this is the output
ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd
it says I'm in the dialout group, so i assumed my permissions were fine. when I do
ls -la /dev/ttyACM0
crw-rw-rw- 1 root dialout 166, 0 Feb 11  2016 /dev/ttyACM0
So there is a problem with my # after dialout its should be 666 right? I tried using
sudo chmod 666 /dev/ttyAMC0
No change to the permissions.
Does anyone know how to change the dialout 166 problem? thanks - or any other solutions that would allow me to open the port or read the GPS Data.
Originally posted by pacifickid9 on ROS Answers with karma: 1 on 2017-11-24
Comment by billy on 2017-11-24:
The error message said there was no file /dev/ACM0, and then you start to explain the effort put into /dev/ttyAMC0. They're not the same thing.
Comment by pacifickid9 on 2017-11-24:
Sorry I miss typed into the launch file parameters, but i retested it with /dev/ttyACM0 and got the same result.
Comment by pacifickid9 on 2017-11-25:
I think i spelled it wrong I got another error so this one must have been solved thanks guys ill be more careful next time!
can you please check again? It's ttyAMC0, not ttyACM0.
After you've changed the launch file / parameters, update your original post to show us the output.
Originally posted by gvdhoorn with karma: 86574 on 2017-11-25
