I study book "Programming Robots with ROS - Morgan Quigley, Brian Gerkey& William D. Smart" in chapter 14. stockroom-bot when run launch file marker.launch
<launch>
  <arg name="marker_size" default="12.3"/>
  <arg name="max_new_marker_error" default="0.2"/>
  <arg name="max_track_error" default="0.8"/>
  <arg name="cam_image_topic" default="/head_camera/rgb/image_raw"/>
  <arg name="cam_info_topic" default="/head_camera/rgb/camera_info"/>
  <arg name="output_frame" default="/base_link"/>
  <node name="ar_track_alvar" pkg="ar_track_alvar" type="individualMarkersNoKinect" respawn="false" output="screen" args="$(arg marker_size) $(arg max_new_marker_error) $(arg max_track_error) $(arg cam_image_topic) $(arg cam_info_topic) $(arg output_frame)" />
  <arg name="tag_rot" default="0 0 0 0 0 -1.57">
  <arg name="tag_trans" default="0 -0.28 -0.1 0 0 0">
  <node pkg="tf" type="static_transform_publisher" name="ar_0_up" args="$(arg tag_rot) ar_marker_0 ar_0_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_1_up" args="$(arg tag_rot)  ar_marker_1 ar_1_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_2_up" args="$(arg tag_rot) ar_marker_2 ar_2_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_3_up" args="$(arg tag_rot) ar_marker_3 ar_3_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_4_up" args="$(arg tag_rot) ar_marker_4 ar_4_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_5_up" args="$(arg tag_rot) ar_marker_5 ar_5_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_6_up" args="$(arg tag_rot) ar_marker_6 ar_6_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_7_up" args="$(arg tag_rot) ar_marker_7 ar_7_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_8_up" args="$(arg tag_rot) ar_marker_8 ar_8_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_9_up" args="$(arg tag_rot) ar_marker_9 ar_9_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_10_up" args="$(arg tag_rot) ar_marker_10 ar_10_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="ar_11_up" args="$(arg tag_rot) ar_marker_11 ar_11_up 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_0" args="$(arg tag_trans) ar_0_up item_0 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_1" args="$(arg tag_trans) ar_1_up item_1 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_2" args="$(arg tag_trans) ar_2_up item_2 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_3" args="$(arg tag_trans) ar_3_up item_3 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_4" args="$(arg tag_trans) ar_4_up item_4 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_5" args="$(arg tag_trans) ar_5_up item_5 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_6" args="$(arg tag_trans) ar_6_up item_6 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_7" args="$(arg tag_trans) ar_7_up item_7 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_8" args="$(arg tag_trans) ar_8_up item_8 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_9" args="$(arg tag_trans) ar_9_up item_9 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_10" args="$(arg tag_trans) ar_10_up item_10 100"/>
  <node pkg="tf" type="static_transform_publisher" name="item_11" args="$(arg tag_trans) ar_11_up item_11 100"/>
</launch>
--then appear error message
... logging to /home/ho/.ros/log/da9b7b56-1299-11e7-83ee-000c29c6431a/roslaunch-ubuntu-51819.log
Press Ctrl-C to interrupt
Invalid roslaunch XML syntax: mismatched tag: line 38, column 2
The traceback for the exception was written to the log file
how can fix it? I run in indigo
Originally posted by deokisys on ROS Answers with karma: 5 on 2017-03-26
There are missing / in the following two tags.
<arg name="tag_rot" default="0 0 0 0 0 -1.57" />
<arg name="tag_trans" default="0 -0.28 -0.1 0 0 0" />
Originally posted by tngan with karma: 46 on 2017-03-27
Replace these lines:
<arg name="tag_rot" default="0 0 0 0 0 -1.57"/>
<arg name="tag_trans" default="0 -0.28 -0.1 0 0 0"/>
You are missing a couple of /
Originally posted by angeltop with karma: 351 on 2017-03-27
