I installed ros groovy recently, and now I got this error frequently when I use command "roscore":
... logging to /home/jingru/.ros/log/52f1ef44-c93e-11e2-8e1d-648099590658/roslaunch-Jingru-Lenovo-11463.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://Jingru-Lenovo:38033/ ros_comm version 1.9.44
SUMMARY
PARAMETERS
  • /rosdistro
  • /rosversion
NODES
You must specify a valid interface name.
After a system reboot, I can launch it successfully. Please help! Thank you in advance.
Originally posted by Jingru on ROS Answers with karma: 11 on 2013-05-30
Solved this with
sudo pip install --upgrade netifaces
(Similar to Jochen's answer above, this upgrades python netifaces.)
Originally posted by Ed Venator with karma: 1185 on 2013-06-24
I've had the same problem on Ubuntu 12.04 and fixed it by installing python-netifaces from 12.10.
HTH
Jochen
Originally posted by Jochen Sprickerhof with karma: 46 on 2013-06-14
Comment by Lucien on 2013-07-08:
I had the same problem but I already installed python-netifaces from 12.04. But I still got the same question. How did you install python-netifaces from 12.10?
