Make Warning at /opt/ros/kinetic/share/cmake_modules/cmake/Modules/FindEigen.cmake:62 (message): The FindEigen.cmake Module in the cmake_modules package is deprecated.
Please use the FindEigen3.cmake Module provided with Eigen. Change instances of find_package(Eigen) to find_package(Eigen3). Check the FindEigen3.cmake Module for the resulting CMake variable names.
Call Stack (most recent call first): ROBOTIS/ROBOTIS-THORMANG-MPC-master/ati_ft_sensor/CMakeLists.txt:17 (find_package)
-- Eigen found (include: /usr/include/eigen3)
Originally posted by GIL on ROS Answers with karma: 1 on 2017-02-22
If this is your package you should make the change described in the warning. If this isn't your package, you can probably ignore the warning or file a ticket on the project's bug tracker.
Originally posted by ahendrix with karma: 47576 on 2017-02-22
