Hi. I've a c++ project where I'm using CMakeList with the structure similar to:
Project (inside my ros sandbox)
|_Folder1
|___some code
|___CMakeLists.txt
|_Folder2
|___some code
|___CMakeLists.txt
|_ROS package folder
|___some code
|___CMakeLists.txt
|_CMakeLists.txt
Inside de main CMakeLists.txt I've something similar to:
add_subdirectory(recruiter)
add_library(something_static STATIC ${RECRUITER_SOURCES})
Where inside "recruiter" directory is the ROS package, created using "roscreate-pkg".
And I'm getting the following error:
[rosbuild] Error from directory check: /opt/ros/groovy/share/ros/core/rosbuild/bin/check_same_directories.py /opt/ros/groovy/stacks/test/noderecruiter 1 Traceback (most recent call last): File "/opt/ros/groovy/share/ros/core/rosbuild/bin/check_same_directories.py", line 46, in raise Exception Exception CMake Error at /opt/ros/groovy/share/ros/core/rosbuild/private.cmake:102 (message): [rosbuild] rospack found package "test" at "", but the current directory is "/opt/ros/groovy/stacks/test/noderecruiter". You should double-check your ROS_PACKAGE_PATH to ensure that packages are found in the correct precedence order. Call Stack (most recent call first): /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:177 (_rosbuild_check_package_location) server/noderecruiter/CMakeLists.txt:12 (rosbuild_init)
What's happening? THanks.
Originally posted by Verane on ROS Answers with karma: 25 on 2013-06-24
Comment by dornhege on 2013-06-24:
Are you building with catkin? I think ROS/catkin needs the toplevel.cmake to work.
Comment by Verane on 2013-06-24:
No, I would like to build like a normal project.
Comment by allenh1 on 2013-06-24:
Could you please post your CMakeLists.txt file in full? It would be good to see the context of your build output.
Comment by Verane on 2013-06-25:
What CMakeLists do you want? The file inside the main project or the ros one?
ROS packages are not designed to simply be included inside CMake packages. This is not a supported use case.
Originally posted by tfoote with karma: 58457 on 2013-08-12
