I've created a simple arm and I want to control it using a joystick.
Here's my launch file:
<launch>
<include file="$(find cougarbot)/cougarbot.launch"/>
<include file="$(find cougarbot_moveit_config)/launch/joystick_control.launch"/>
<include file="$(find cougarbot_moveit_config)/launch/move_group.launch"/>
<include file="$(find cougarbot_moveit_config)/launch/moveit_rviz.launch">
<arg name="config" value="True"/>
</include>
</launch>
The error I'm getting is from joystick_control.launch is "[FATAL] Check if you started movegroups. Exiting." Here's the full stack trace:
$ roslaunch cougarbot_moveit_config joystick_control.launch
[ INFO] [1486692499.658150322]: Loading robot model 'cougarbot'...
[ INFO] [1486692499.659144317]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ WARN] [1486692499.660517007]: Could not identify parent group for end-effector 'hand'
[ INFO] [1486692500.876474349, 182.851000000]: Loading robot model 'cougarbot'...
[ INFO] [1486692500.877637693, 182.851000000]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ WARN] [1486692500.878770531, 182.851000000]: Could not identify parent group for end-effector 'hand'
[FATAL] [WallTime: 1486692501.117867] [0.000000] Check if you started movegroups. Exiting.
File "/opt/ros/indigo/lib/moveit_ros_visualization/moveit_joy.py", line 42, in <module>
app = MoveitJoy()
File "/opt/ros/indigo/lib/python2.7/dist-packages/moveit_ros_visualization/moveitjoy_module.py", line 381, in __init__
self.updatePlanningGroup(0)
File "/opt/ros/indigo/lib/python2.7/dist-packages/moveit_ros_visualization/moveitjoy_module.py", line 405, in updatePlanningGroup
raise rospy.ROSInitException(msg)
rospy.exceptions.ROSInitException: Check if you started movegroups. Exiting.
Originally posted by danielsnider on ROS Answers with karma: 203 on 2017-02-11
