Hi,
is there a way to plan a path to a goal which is defined with a position (x, y, z) and a value for pitch and roll, but leave yaw open for variation? For my use case the yaw angle is not relevant, so I don't want to restrict possible paths by defining a value for it.
As far as I understand not giving a value for the axis will not work, because the value is initialized to zero.
Another approach would be to set the goal_orientation_tolerance. However, this is quite unsatisfying as this sets the tolerance for the whole pose and not only one specific axis.
Originally posted by F4bich on ROS Answers with karma: 79 on 2016-11-26
Comment by gvdhoorn on 2016-11-26:
Not an answer, but this would seem like something descartes is very good at:
Descartes is a ROS-Industrial project for performing path-planning on under-defined Cartesian trajectories
Cartesian only though.
Comment by NEngelhard on 2016-11-26:
I think this could be implemented with a OrientationConstraint. I haven't used it yet, but I think you could set the absolute_z_axis_tolerance to something small and the other two much larger.
Comment by gvdhoorn on 2016-11-27:
s are also definitely possible. Would remove the need for any additional planners. I just wanted to give a pointer to a planner that might be better suited for underconstrained planning problems.
Comment by F4bich on 2016-11-28:
As far as I understand these are constraints one can limit the possible paths with. Therefore, an OrientationConstraint would only solve the problem, when the scenario is something like moving in a straight line, otherwise the constraint has a high chance of preventing us to find any path.
