Hi there,
I am following this tutorial http://wiki.ros.org/Industrial/Tutorials/Create_a_MoveIt_Pkg_for_an_Industrial_Robot
in order to move my real ur5. So far I get the simulated robot running using the demo.launch file from https://github.com/ros-industrial/universal_robot.
After specifying a desired end-effector position in the cartesian frame ( in the rviz gui) I often receive path planning which seems to be not very cost efficient. Furthermore, my robot will be mounted on a flat surface which means that the robot will collide in case any point is below z=0 of the base(world) frame.
How can I constrain the path planning in order to only get paths wich are limited to my reachable task space?
Originally posted by psfa_fz on ROS Answers with karma: 36 on 2014-10-08
Personally I'd only use CollisionObjects for objects that you need to be able to add to and remove from a scene. For (semi) static objects I'd use one of the object representation formats that ROS supports.
  1. Create a sufficiently detailed 'work cell' and add it to your URDF: you mention a 'flat surface' (table?) on which your robot is mounted. Model your environment, including the table and any other objects / obstacles that are in your cell. Besides restricting the planning space, this also helps visualisation. You will have to (re)generate a MoveIt configuration package for the combination of work cell & manipulator URDF.
  2. Use the MoveIt .scene format to describe your work cell and load that using the appropriate APIs (or button in RViz).
See the MoveIt Environment Representation tutorial for some pointers on this.
You can find an example of a URDF of a modelled work cell in Exercise 3.1 - Workcell XACRO of the ROS-Industrial Training Exercises.
Originally posted by gvdhoorn with karma: 86574 on 2014-10-09
