Hello guys,
I'm currently working on a ABB robot (IRB140) which should fulfill following task: It should balance a ball on a tray. This means I have to stream the latest position in Z-direction which the robot should take place in. X,Y and the Orientation always stays the same, only Z varies.
Balancing a ball http://www2.pic-upload.de/img/29636820/ABBIRB140.jpg
Which would be the right approach in Moveit? Cartesian Path with waypoints? Normal planning but with Asyncmove? Problem is: Imagine the robot is on its way from z=0 to z= -0.5. But then the vision system says it should go to z= +0.5. Then it would be necessery that the robot reverses immediately and ignores the old goal z= -0.5.
Regards and thank you very much for your help! Timo
Originally posted by cobhc999 on ROS Answers with karma: 38 on 2016-02-04
