I am working with ROS Indigo and MoveIt! and I already set up my robot through the setup assistant, and In Rivz I can see the start and goal state, in green and orange. I can manually move the orange goal state from Rviz and then plan and execute a trajectory in order to reach it. Otherwise, I have a piece of code that sets a goal trajectory and plans and executes the whole trajectory to it.
But I would like to just move the (orange) goal state to a new position through a piece of code, without planning any trajectory. Just changing the goal state. How can I do it?
Originally posted by HenrySleek on ROS Answers with karma: 53 on 2017-03-20
Comment by v4hn on 2017-03-21:
Please stop editing your posts over and over again. This sends out notification emails every time to everyone who watches ros-answers.
Comment by HenrySleek on 2017-03-22:
Oh damn, I am sorry, I didn't know. I just wanted to have it pop up at the top of the question list in the Home page. I will stop now that I have an answer.
Comment by levi strauss on 2018-07-03:
Hey you said that you had a piece of code that sets a goal trajectory and plans and executes that trajectory? I am struggling to figure out how to do this, would you mind giving some details?
MoveIt's RViz display is mostly independent. The orange goal state corresponds to the goal state of the display only. There is no such thing as a "global goal state".
So actually you are looking for a way to tell the motion planning display to update the robot state it maintains as its goal state. Others asked for more general remote-control functionality of the whole motion planning display in the past. There is no satisfying implementation of this at the moment. Someone implemented a small part of it a while ago, but apparently lost interest. Since then, nobody provided patches to improve on the current state...
So this is what you can do out of the box:
If you check the "Allow External Comm." box in the planning tab, then you can send an std_msgs/Empty message to the /rviz/moveit/update_goal_state topic and the goal state will be set to the current state of the robot.
This is setup here: https://github.com/ros-planning/moveit/blob/kinetic-devel/moveit_ros/visualization/motion_planning_rviz_plugin/src/motion_planning_frame.cpp#L212
and implemented https://github.com/ros-planning/moveit/blob/kinetic-devel/moveit_ros/visualization/motion_planning_rviz_plugin/src/motion_planning_frame_planning.cpp#L430 .
It is pretty straight-forward and at most an afternoon of work to add another callback that receives a moveit_msgs/RobotState.msg and updates the start state or goal state with it.
A patch for this (and a pull-request for the moveit repository) would be awesome!
Originally posted by v4hn with karma: 2950 on 2017-03-21
Post score: 4
Comment by HenrySleek on 2017-03-21:
I checked that code and indeed it's really a pity that nobody tried to expand it. Anyway, maybe it is enough to call a planning_display_->setQueryGoalState(state); setting the wanted state. Though, trying it, I have the following problem: http://answers.ros.org/question/257528/include-qwidget/
Yes and no. You can't do that from outside the rviz display, i.e. from your own node. You can just add another callback and subscriber though, that receives a moveit_msgs/RobotState.msg and calls planning_display_->setQueryGoalState() with that one.
I see. But I prefer not modifying the source code, since now it's installed with binaries and I didn't want to put my hands on it. Is there a way for doing it with MoveIt! installed from binaries?
Comment by v4hn on 2017-03-22:
It is quite easy to compile moveit locally (see install section on the website). If you implement the missing function and add a pull-request to the repository, we could have it in the next release and then you don't need your own source build anymore :) This is how open source contributions work...
If you are not willing to edit MoveIt source code, then no. You can't change the goal start arbitrarily (until someone contributed this functionality).
Comment by phy on 2018-04-04:
A tested patch is available here: https://github.com/phy25/moveit/tree/ext-RobotState . A PR will be made soon.
Comment by RicoJ on 2020-11-13:
Hi, I know this is kinda old, but recently I'm running into the same challenge. I am trying to send goal states through /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/update, but I saw that Rviz's display update rate become significantly slower. I guess you can verify this by trying the same thing.
Right now I am trying to increase Rviz display's speed. Any idea?
