Hello, I am new to ROS. I have been trying to do usb camera integration into a robotics project at our university's lab. I will write the steps i did and the errors that i got.
I went into my ~/catkin_ws/src folder and i ran
git clone https://github.com/bosch-ros-pkg/usb_cam
Then I went into my ~/catkin_ws folder and ran
source /devel/setup.bash
Then I ran
roscore
Then I ran
roslaunch usb_cam usb_cam-test.launch
This was the output ... logging to /home/submetu/.ros/log/1fd73732-55ad-11e6-a65d-d8fc93edb7dc/roslaunch-submetu-9724.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://submetu:40095/
SUMMARY
PARAMETERS
- /image_view/autosize: True
- /rosdistro: kinetic
- /rosversion: 1.12.2
- /usb_cam/camera_frame_id: usb_cam
- /usb_cam/image_height: 480
- /usb_cam/image_width: 640
- /usb_cam/io_method: mmap
- /usb_cam/pixel_format: yuyv
- /usb_cam/video_device: /dev/video0
NODES / image_view (image_view/image_view) usb_cam (usb_cam/usb_cam_node)
core service [/rosout] found process[usb_cam-1]: started with pid [9742] ERROR: cannot launch node of type [image_view/image_view]: can't locate node [image_view] in package [image_view] [ INFO] [1469813059.142822397]: using default calibration URL [ INFO] [1469813059.142904972]: camera calibration URL: file:///home/submetu/.ros/camera_info/head_camera.yaml [ INFO] [1469813059.142970068]: Unable to open camera calibration file [/home/submetu/.ros/camera_info/head_camera.yaml] [ WARN] [1469813059.142995991]: Camera calibration file /home/submetu/.ros/camera_info/head_camera.yaml not found. [ INFO] [1469813059.143027047]: Starting 'head_camera' (/dev/video0) at 640x480 via mmap (yuyv) at 30 FPS [ERROR] [1469813064.141746901]: VIDIOC_S_FMT error 5, Input/output error terminate called after throwing an instance of 'boost::exception_detail::clone_implboost::exception_detail::error_info_injector<boost::lock_error >' what(): boost: mutex lock failed in pthread_mutex_lock: Invalid argument [usb_cam-1] process has died [pid 9742, exit code -6, cmd /home/submetu/catkin_ws/devel/lib/usb_cam/usb_cam_node __name:=usb_cam __log:=/home/submetu/.ros/log/1fd73732-55ad-11e6-a65d-d8fc93edb7dc/usb_cam-1.log]. log file: /home/submetu/.ros/log/1fd73732-55ad-11e6-a65d-d8fc93edb7dc/usb_cam-1*.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
I tried the tutorial of http://wiki.ros.org/camera_calibration , but I am not getting any camera output because the above error comes everytime. So I cant calibrate i.e. i cant get the head_camera.yaml file. I looked at many tutorials but I could not find anything helpful to me.
Please help :(
Thank you in advance (im using a lenovo thinkpad e440 with ubuntu. My camera is a logitech camera(it is connected as cheese is giving video output))
Originally posted by submetu on ROS Answers with karma: 46 on 2016-07-29
