I am trying to use Dynamixel motors on ROS-kinect. I am giving this command.
khan@ubuntu:~$ sudo apt-get install ros-kinetic-dynamixel-motor
and getting this response. I am also trying to install it on Raspberry Pi 3 in which I have installed Jessie Kinetic and having the same response which is as follows.
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-kinetic-dynamixel-motor
Your response is much appreciated. Thank you.
Originally posted by Abdul Mannan on ROS Answers with karma: 167 on 2016-07-26
I got dynamixel package running on Kinetic. It is not in apt-get repository yet.
Just create workspace, do git clone of dynamixel repository, then catkin_make. Don't forget to add appropriate source setup.sh line to your .bashrc and restart terminal/roscore before using. It should compile without errors on Ubuntu 16.04 (tested on PC only).
Create normal worksapce:
~$ mkdir -p ~/my_workspace/src
~$ cd ~/my_workspace/src
~$ catkin_init_workspace
Clone dynamixel source code and compile:
~$ git clone https://github.com/arebgun/dynamixel_motor.git
~$ catkin_make
Add your new worksapce to bashrc and source it (so it is visible to roslaunch)
~$ echo "source ~/my_workspace/devel/setup.bash" >> ~/.bashrc
~$ source ~/.bashrc
Run your shiny new dynamixel manager:
~$ roslaunch dynamixel_tutorials controller_manager.launch
Should work on Ubuntu 16.04
Originally posted by Marcin Bogdanski with karma: 231 on 2016-07-31
Comment by Abdul Mannan on 2016-08-19:
Oh, dear could you please share the link for that clone and method. I have no idea about it. Thank you so much.
Comment by Marcin Bogdanski on 2016-08-25:
Hi. Sorry for late reply, I was super busy over last couple days. See edited answer
Comment by Abdul Mannan on 2016-08-28:
It worked. :). Thank you so Much Marcin Bogdanski.
