I have 2 computers running ROS and I'm trying to connect them via an Ethernet cable. Both machines are also connected to the Internet via wireless connection.
An intel NUC as the master at 10.0.0.2 An Tegra-k1 as the client at 10.0.0.3
NUC (Master at 10.0.0.2)
export ROS_IP=10.0.0.2
export ROS_HOSTNAME=10.0.0.2
export ROS_MASTER_URI=http://10.0.0.2:11311
roscore
Tegra (Client at 10.0.0.3)
export ROS_IP=10.0.0.3
export ROS_HOSTNAME=10.0.0.3
roscore
roscore output from Master
... logging to /home/ubuntu/.ros/log/e8292188-4152-11e6-9eb6-00c2c6b4df39/roslaunch-nuc-16093.log
Press Ctrl-C to interrupt
started roslaunch server http://10.0.0.2:40088/
ros_comm version 1.12.2
SUMMARY
PARAMETERS
* /rosdistro: kinetic
* /rosversion: 1.12.2
NODES
auto-starting new master
process[master]: started with pid [16104]
ROS_MASTER_URI=http://10.0.0.2:11311/
setting /run_id to e8292188-4152-11e6-9eb6-00c2c6b4df39
process[rosout-1]: started with pid [16119]
started core service [/rosout]
roscore output from Client
... logging to /home/ubuntu/.ros/log/014001fe-4154-11e6-85b6-60601f199a6b/roslaunch-tegra-ubuntu-3583.log
started roslaunch server http://10.0.0.3:35762/
ros_comm version 1.11.19
SUMMARY
PARAMETERS
* /rosdistro: indigo
* /rosversion: 1.11.19
NODES
WARNING: ROS_MASTER_URI [http://10.0.0.2:11311] host is not set to this machine
process[master]: started with pid [3594]
ROS_MASTER_URI=http://10.0.0.3:11311/
setting /run_id to 014001fe-4154-11e6-85b6-60601f199a6b
process[rosout-1]: started with pid [3607]
I have have multiple network interfaces on both machines
ifconfig output from Master
eno1 Link encap:Ethernet HWaddr b8:ae:ed:e9:81:d9
inet addr:10.0.0.2 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::d43d:9fd2:6b7e:6161/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1070691 errors:0 dropped:0 overruns:0 frame:0
TX packets:2245 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1478861461 (1.4 GB) TX bytes:234854 (234.8 KB)
Interrupt:16 Memory:df200000-df220000
enx00e08f007010 Link encap:Ethernet HWaddr 00:e0:8f:00:70:10
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:93462668 errors:0 dropped:0 overruns:0 frame:0
TX packets:93462668 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:843898338519 (843.8 GB) TX bytes:843898338519 (843.8 GB)
wlp1s0 Link encap:Ethernet HWaddr 00:c2:c6:b4:df:39
inet addr:192.168.2.101 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::db69:417b:b13f:fe0c/64 Scope:Link
RX packets:188727 errors:0 dropped:0 overruns:0 frame:0
TX packets:73771 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:143274712 (143.2 MB) TX bytes:12915443 (12.9 MB)
ifconfig from client
eth0 Link encap:Ethernet HWaddr 60:60:1f:19:9a:6b
inet addr:10.0.0.3 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::6260:1fff:fe19:9a6b/64 Scope:Link
RX packets:1763 errors:0 dropped:0 overruns:0 frame:0
TX packets:1070511 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:172255 (172.2 KB) TX bytes:1474299487 (1.4 GB)
RX packets:2803 errors:0 dropped:0 overruns:0 frame:0
TX packets:2803 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:360418 (360.4 KB) TX bytes:360418 (360.4 KB)
wlan0 Link encap:Ethernet HWaddr 7c:5c:f8:73:59:dd
inet addr:192.168.2.111 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::7e5c:f8ff:fe73:59dd/64 Scope:Link
RX packets:8674 errors:0 dropped:0 overruns:0 frame:0
TX packets:1837 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4127822 (4.1 MB) TX bytes:253977 (253.9 KB)
I had the network working earlier this month, but right now it doesn't want to work.
The computers definitely do see each other.
On Master the following works
ping 10.0.0.3
On Client the following works
ping 10.0.0.2
Also, I have UDP client server that has no problems transferring images over the Ethernet cable between the two computers.
Originally posted by uwleahcim on ROS Answers with karma: 101 on 2016-07-03
