New to ROS so thanks in advance for your patience!
My planned network architecture consists of a central computer connected via wifi to several (10+) mobile robots. I would like to use ROS to send high level commands from the central computer to the robots, and also to receive high level telemetry information.
But, I will also have several ROS nodes on each individual robot (on a single processor) which will be passing data back and forth with each other. This on-robot processing will happen at a much higher rate than the communication between the central computer and the robots. Note the individual robots won't talk directly to each other at all.
I plan to run my roscore master on the central computer. My concern is about possible network congestion with the ROS traffic on each individual robot. Question 1) Does all ROS traffic pass through the master? Or would messages between nodes residing on a single machine (not the master) stay fully on that machine?
Also, I may have situations where individual robots enter a region with spotty wifi signal, and so will temporarily not have a connection with the master. Question 2) Will that robot's communication between its own ROS nodes (not with the central computer's nodes) be affected by a potential dropout of the connection with the ROS master?
Originally posted by mechapancake on ROS Answers with karma: 3 on 2020-02-01
There are several duplicates of these questions on this site -- but I can't find them without Googling too long, so I'll answer this again.
No, this is not MQTT with a broker. Messages are exchanged peer-to-peer.
(this is the complement of your earlier question, so): yes.
Theoretically: no, as long as no new connections are being setup, things should keep working, as the master is only involved in setting up new subscriptions and other connections between nodes (it's essentially a DNS).
In practice this is almost never the case, and things will stop working (or most likely: start to time-out).
You'll want to run a master on each individual robot instead. This is almost always recommended when having this many robots.
Look into multimaster_fkie and similar packages.
Originally posted by gvdhoorn with karma: 86574 on 2020-02-02
Comment by gvdhoorn on 2020-02-02:
In addition to this: I'd recommend you spend a few minutes reading wiki/ROS/Introduction. It will clear up a lot of things (including what the role of the master is).
Also: note that ROS 2 is different in this regard: it's fully peer-to-peer. No centralised discovery.
Comment by mechapancake on 2020-02-03:
Thanks for clearing that up. So network traffic doesn't route through the master, but the master still needs to be periodically accessible to avoid problems due to time-outs. Or are the time-outs you refer to something else?
Comment by gvdhoorn on 2020-02-03:
The time-outs are due to this:
the master is [..] involved in setting up new subscriptions
So nodes will start to time-out when they are trying to setup new connections.
But if you setup a proper multi-master setup that will not be a problem -- as each robot is its own master.
No, there's nothing periodic about it. It all depends on when nodes want to subscribe to a new topic or want to execute a service.
Comment by mechapancake on 2020-02-04:
So it seems my options are ROS+multimaster_fkie (or similar) or ROS 2. After looking into ROS 2 a bit, it seems like that might be the way to go, since I'm just starting out anyway. Regarding my original question about network congestion, is there any reason to stick with ROS+multimaster_fkie or should I just go ROS 2?
Comment by gvdhoorn on 2020-02-04:
Personally I would not make this decision based on network utilisation alone.
ROS 2 is certainly an option, but realise there is far less in terms of documentation, examples, books and available software for it. ROS 1 is certainly not perfect, but if you're really just starting out, you may benefit tremendously from having existing systems and a community to lean on.
Unfortunately I cannot make this decision for you, as it will depend on many factors that I don't know.
