I have created a project from terminal and i was able to run successfully. When try to configure eclipse for the same project, but the project is not visible in eclipse. Hence, i am not able open and run my project in eclipse.
here is the steps i followed.
cd path/to/catkin/workspace
catkin_make --force-cmake -G"Eclipse CDT4 - Unix Makefiles" -DCMAKE_BUILD_TYPE=Debug -DCMAKE_ECLIPSE_MAKE_ARGUMENTS=-j8
After running the above command, .project and .cproject files are created in the <catkin_workspace>/build directory. then i tried to import my project Click File -> Import -> Existing Projects into Workspace (Next) -> Browse (browse to catkin_workspace -> My project is not visible here :-( ,
i noticed my project is not appearing in the .project file. why my project is missing in .project and how can i open it in eclipse. Can anyone please help me on this?
Originally posted by anilmullapudi on ROS Answers with karma: 75 on 2016-06-02
Comment by ahendrix on 2016-06-02:
I assume you're following the instructions in http://wiki.ros.org/IDEs
Comment by anilmullapudi on 2016-06-03:
Yes, i followed instructions in http://wiki.ros.org/IDEs. But project was not visible to import from eclipse.
