There are many things that you might be missing:
When doing catkin_make make sure that you have done catkin_make --force-cmake -G"Eclipse CDT4 - Unix Makefiles"
otherwise the Eclipse configuration files are not going to be there ( I assume this is OK). To validate this, in your build/
folder there should be two files: .cproject
and .project
I assume you are following the IDEs tutorial exactly as they say (regarding how Eclipse should be installed). Specially, regarding how you launch Eclipse. In my case, I have a EclipseROS.desktop
file in~/.local/share/applications/
that looks as follows:
[Desktop Entry]
Name=Eclipse 4
Type=Application
Exec=env SWT_GTK3=1 bash -i -c "/opt/eclipse/eclipse"
Terminal=false
Icon=/opt/eclipse/icon.xpm
Comment=Integrated Development Environment
NoDisplay=false
Categories=Development;IDE;
Name[en]=EclipseROS
Name[en_US]=EclipseROS
And my .bashrc
constains source
~/catkin_ws/devel/setup.bash`.
- Finally, simply browse in your
build/
folder, do not go down to the package folder, because is in build where the Eclipse configuration files .cproject
and .project
are generated (at least for catkin_make
, for catkin tools
a couple of files is generated for every package).
Originally posted by Javier V. Gómez with karma: 1305 on 2016-02-26
Comment by Randerson on 2016-02-26:
Thanks, everything was corrected but instead of browse in the build/ folder I was browsing in the packge folders. Naive mistake.
