Hi, I'm a new user for the Baxter robot. Currently, I'm trying to setup the working environment on my computer by following the Baxter Wiki provide instruction. but until to the step of Verify Development Workstation Ping, I faced one problem. I can identify my ROS_IP but when I going to SSH to Baxter and verify the ability to communicate with my development PC, it shows me Persimmon denied. this is the code I follow:
$ ssh ruser@<our ROS Master>
# Password: rethink
# Example:
$ ssh [email protected]
of course, my ROS Master was different with the example. Then after that, it asks me to enter the password which is the rethink, but I try three times. in the end, shows me Persimmon denied.
Does anyone have the same problem before? By the way, I'm using ubuntu 14.04 64bit indigo and robot system version was 0.0.28
Thank you
image description
Originally posted by Zero on ROS Answers with karma: 104 on 2016-05-19
The obvious first thing to check is whether that username & password combination is actually correct. Has someone changed it without letting you know?
In any case this is probably something you should contact Rethink about: they have quite an extensive support site and should be able to help you.
Originally posted by gvdhoorn with karma: 86574 on 2016-05-20
Comment by Zero on 2016-05-20:
I had tried to find whether anyone had change the password nd username before, but I cannot retrieve back the history who had handled the robot before.
In addition, I had sent the email to the support team ask for help, but they still not reply me yet.
Anyway, I really appreciate your advice
