I'm having trouble launching nodes remotely using launch files and need some help. Even using ssh keys roslaunch still cannot find the remote computer (despite it stating that it started the ssh session). I'm running Indigo with Ubuntu 14.04 on both my workstation computer and the computer aboard the robot, I'm not setting any parameters, and I don't have ROS_HOSTNAME set, only ROS_IP which is 192.168.1.103 for the workstation (master) and 192.168.1.212 for the robot. These are the steps that have been taken so far:
  1. Went through the ROS Network Setup Tutorial and made sure that the machines can ping each other and used netcat to check that communication over ports is possible.
  2. Create an RSA ssh key to make it possible to ssh into a machine without a password (and checked it).
  3. Used ssh -oHostKeyAlgorithms='ssh-rsa' host when making the first connection as shown in this answer
  4. Followed the example in the roslaunch machine tag wiki.
  5. Tried using the ROSLAUNCH_SSH_UNKNOWN environment variable
  6. Tried steps 4 and 5 with a DSA key, but still no luck.
The robot can still be sshed into and can have code run from there and everything works normally (can see data coming in from topics from the robot, etc.) so I don't think that it's a network issue (although it could be). It's just the launching using machine tags that doesn't work. Here's the test launch file (talker.launch) that I've been using:
<launch>
    <machine name="robot" user="ngcneuro" address="red2" default="true" env-loader="/opt/ros/indigo/env.sh"/>
    <node pkg="beginner_tutorials" name="talker" type="talker.py" machine="robot" />
</launch>
My package is called test_machine and here's what ROS master is telling me after running:
$ roslaunch test_machine talker.launch
... logging to /home/ngcneuro/.ros/log/7ce15492-50a4-11e7-8d3e-40167e358fbd/roslaunch-NGNeuromorphic1-14982.log
Press Ctrl-C to interrupt
started roslaunch server http://192.168.1.103:59087/
remote[red2-0] starting roslaunch
remote[red2-0]: creating ssh connection to red2:22, user[ngcneuro]
/usr/lib/python2.7/dist-packages/Crypto/Cipher/blockalgo.py:141: FutureWarning: CTR mode needs counter parameter, not IV
  self._cipher = factory.new(key, *args, **kwargs)
launching remote roslaunch child with command: [env ROS_MASTER_URI=http://192.168.1.103:11311 /opt/ros/indigo/env.sh roslaunch -c red2-0 -u http://192.168.1.103:59087/ --run_id 7ce15492-50a4-11e7-8d3e-40167e358fbd]
remote[red2-0]: ssh connection created
SUMMARY
PARAMETERS
 * /rosdistro: indigo
 * /rosversion: 1.11.21
MACHINES
 * robot
NODES
    talker (beginner_tutorials/talker.py)
core service [/rosout] found
^C[red2-0] killing on exit
^Cerror launching on [red2-0, uri http://robot:39508/]: Interrupted system call
Launch of the following nodes most likely failed: beginner_tutorials/talker.py
^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^C^X^X^X^C^C^C^Cremote[red2-0]: unable to contact [red2] to shutdown remote processes!
shutting down processing monitor...
... shutting down processing monitor complete
done
It takes several minutes to regain control of the terminal, even after using Ctrl-C several times. And here's my roslaunch log:
[roslaunch][INFO] 2017-06-13 18:57:26,124: Checking log directory for disk usage. This may take awhile.
[roslaunch][INFO] 2017-06-13 18:57:26,130: Done checking log file disk usage. Usage is <1GB.
[roslaunch][INFO] 2017-06-13 18:57:26,131: roslaunch starting with args ['/opt/ros/indigo/bin/roslaunch', 'test_machine', 'talker.launch']
[roslaunch][INFO] 2017-06-13 18:57:26,132: roslaunch env is {'CPU_ONLY': '0', 'XDG_DATA_DIRS': '/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/', 'XDG_SESSION_ID': 'c2', 'MANDATORY_PATH': '/usr/share/gconf/ubuntu.mandatory.path', 'CUDA_MINOR_NUM': '5', 'COMPIZ_CONFIG_PROFILE': 'ubuntu', 'CARLSIM_FASTMATH': '0', 'JOB': 'dbus', 'SESSION': 'ubuntu', 'XMODIFIERS': '@im=ibus', 'JAVA_HOME': '/usr/lib/jvm/java-8-oracle', 'TURTLEBOT_INTERACTIONS_LIST': '[turtlebot_bringup/admin.interactions, turtlebot_bringup/documentation.interactions, turtlebot_bringup/pairing.interactions, turtlebot_bringup/visualisation.interactions]', 'SELINUX_INIT': 'YES', 'XDG_RUNTIME_DIR': '/run/user/1000', 'PYTHONPATH': '/home/ngcneuro/ca_ws/devel/lib/python2.7/dist-packages:/opt/ros/indigo/lib/python2.7/dist-packages:/usr/lib/pymodules/python2.7/:/home/ngcneuro/opt/nest/lib/python2.7/site-packages', 'COMPIZ_BIN_PATH': '/usr/bin/', 'J2SDKDIR': '/usr/lib/jvm/java-8-oracle', 'ROS_ROOT': '/opt/ros/indigo/share/ros', 'CUDA_INSTALL_PATH': '/usr/local/cuda-6.5', 'DBUS_SESSION_BUS_ADDRESS': 'unix:abstract=/tmp/dbus-MzFRSBiRBN', 'ORBIT_SOCKETDIR': '/tmp/orbit-ngcneuro', 'DEFAULTS_PATH': '/usr/share/gconf/ubuntu.default.path', 'DESKTOP_SESSION': 'ubuntu', 'GTK_MODULES': 'overlay-scrollbar:unity-gtk-module', 'INSTANCE': '', 'TURTLEBOT_GAZEBO_WORLD_FILE': '/opt/ros/indigo/share/turtlebot_gazebo/worlds/playground.world', 'TURTLEBOT_3D_SENSOR': 'asus_xtion_pro', 'TURTLEBOT_RAPP_PACKAGE_BLACKLIST': '[]', 'XDG_MENU_PREFIX': 'gnome-', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:', 'TURTLEBOT_TYPE': 'turtlebot', 'BASH_FUNC_module%%': '() {  eval `/usr/bin/modulecmd bash $*`\n}', 'GNOME_DESKTOP_SESSION_ID': 'this-is-deprecated', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'TURTLEBOT_MAP_FILE': '/opt/ros/indigo/share/turtlebot_navigation/maps/willow-2010-02-18-0.10.yaml', 'CPATH': '/home/ngcneuro/ca_ws/devel/include:/opt/ros/indigo/include', 'USER': 'ngcneuro', 'XDG_VTNR': '7', 'CMAKE_PREFIX_PATH': '/home/ngcneuro/ca_ws/devel:/opt/ros/indigo', 'AMDAPPSDKROOT': '/opt/AMDAPP', 'XAUTHORITY': '/home/ngcneuro/.Xauthority', 'LANGUAGE': 'en_US', 'SESSION_MANAGER': 'local/NGNeuromorphic1:@/tmp/.ICE-unix/2896,unix/NGNeuromorphic1:/tmp/.ICE-unix/2896', 'CARLSIM_LIB_DIR': '/opt/CARL/CARLsim', 'QT_QPA_PLATFORMTHEME': 'appmenu-qt5', 'DISPLAY': ':0', 'CLUTTER_IM_MODULE': 'xim', 'WINDOWID': '56623108', 'GPG_AGENT_INFO': '/run/user/1000/keyring-S68IVz/gpg:0:1', 'MODULESHOME': '/usr/share/modules', 'GDMSESSION': 'ubuntu', 'SHELL': '/bin/bash', 'XDG_SEAT_PATH': '/org/freedesktop/DisplayManager/Seat0', 'ROS_PACKAGE_PATH': '/home/ngcneuro/ca_ws/src:/opt/ros/indigo/share:/opt/ros/indigo/stacks', 'TURTLEBOT_BASE': 'kobuki', '_': '/opt/ros/indigo/bin/roslaunch', 'MODULEPATH': '/etc/environment-modules/modules:/usr/share/modules/versions:/usr/Modules/$MODULE_VERSION/modulefiles:/usr/share/modules/modulefiles', 'GTK_IM_MODULE': 'ibus', 'XDG_CONFIG_DIRS': '/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg', 'TURTLEBOT_BATTERY': '/sys/class/power_supply/BAT0', 'TURTLEBOT_GAZEBO_MAP_FILE': '/opt/ros/indigo/share/turtlebot_gazebo/maps/playground.yaml', 'ROS_MASTER_URI': 'http://192.168.1.103:11311', 'COLORTERM': 'gnome-terminal', '_LMFILES_': '/usr/share/modules/modulefiles/zds/zds-1.1.0.60', 'CARLSIM_CUOPTLEVEL': '3', 'MODULE_VERSION': '3.2.10', 'XDG_GREETER_DATA_DIR': '/var/lib/lightdm-data/ngcneuro', 'QT4_IM_MODULE': 'xim', 'TERMINATOR_UUID': 'urn:uuid:54cc3f7f-1b2b-40a6-b68f-8f0873775c0a', 'PKG_CONFIG_PATH': '/home/ngcneuro/ca_ws/devel/lib/pkgconfig:/opt/ros/indigo/lib/pkgconfig:/opt/ros/indigo/lib/x86_64-linux-gnu/pkgconfig:/usr/local/lib/pkgconfig', 'ROS_IP': '192.168.1.103', 'ZDS_ROOT': '/opt/qualcomm/zeroth/zds-1.1.0.60', 'HOME': '/home/ngcneuro', 'LD_LIBRARY_PATH': '/home/ngcneuro/ca_ws/devel/lib:/opt/ros/indigo/lib:/opt/ros/indigo/lib/x86_64-linux-gnu:/usr/local/cuda-6.5/lib64:/opt/qualcomm/zeroth/zds-1.1.0.60/lib:/opt/AMDAPP/lib/x86_64:/opt/AMDAPP/lib/x86:/usr/local/lib', 'LANG': 'en_US.UTF-8', 'ROS_LOG_FILENAME': '/home/ngcneuro/.ros/log/7ce15492-50a4-11e7-8d3e-40167e358fbd/roslaunch-NGNeuromorphic1-14982.log', 'TURTLEBOT_SIMULATION': 'false', 'TEXTDOMAIN': 'im-config', 'CUDA_HOME': '/usr/local/cuda-6.5', 'ROSLAUNCH_SSH_UNKNOWN': '0', 'TURTLEBOT_SERIAL_PORT': '/dev/kobuki', 'XDG_CURRENT_DESKTOP': 'Unity', 'TURTLEBOT_NAME': 'turtlebot', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'GNOME_KEYRING_PID': '2690', 'ROS_ETC_DIR': '/opt/ros/indigo/etc/ros', 'J2REDIR': '/usr/lib/jvm/java-8-oracle/jre', 'ROS_DISTRO': 'indigo', 'CARLSIM_CUDAVER': '6.5', 'ROSLISP_PACKAGE_DIRECTORIES': '/home/ngcneuro/ca_ws/devel/share/common-lisp', 'QT_IM_MODULE': 'ibus', 'LOGNAME': 'ngcneuro', 'XDG_SEAT': 'seat0', 'GNOME_KEYRING_CONTROL': '/run/user/1000/keyring-S68IVz', 'PATH': '/opt/ros/indigo/bin:/usr/local/cuda-6.5/bin:/usr/local/texlive/2015/bin/x86_64-linux/:/opt/qualcomm/zeroth/zds-1.1.0.60/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin', 'TERM': 'xterm', 'XDG_SESSION_PATH': '/org/freedesktop/DisplayManager/Session0', 'TURTLEBOT_STACKS': 'hexagons', 'TURTLEBOT_RAPP_PACKAGE_WHITELIST': '[rocon_apps, turtlebot_rapps]', 'SESSIONTYPE': 'gnome-session', 'IM_CONFIG_PHASE': '1', 'GIO_LAUNCHED_DESKTOP_FILE_PID': '31090', 'GIO_LAUNCHED_DESKTOP_FILE': '/usr/share/applications/terminator.desktop', 'MODULE_VERSION_STACK': '3.2.10', 'CUDA_MAJOR_NUM': '3', 'SSH_AUTH_SOCK': '/run/user/1000/keyring-S68IVz/ssh', 'TEXTDOMAINDIR': '/usr/share/locale/', 'DERBY_HOME': '/usr/lib/jvm/java-8-oracle/db', 'UPSTART_SESSION': 'unix:abstract=/com/ubuntu/upstart-session/1000/2693', 'OLDPWD': '/home/ngcneuro/ca_ws/src/test_laser', 'LOADEDMODULES': 'zds/zds-1.1.0.60', 'GDM_LANG': 'en_US', 'SHLVL': '1', 'PWD': '/home/ngcneuro/ca_ws/src/test_machine'}
[roslaunch][INFO] 2017-06-13 18:57:26,132: starting in server mode
[roslaunch.parent][INFO] 2017-06-13 18:57:26,132: starting roslaunch parent run
[roslaunch][INFO] 2017-06-13 18:57:26,133: loading roscore config file /opt/ros/indigo/etc/ros/roscore.xml
[roslaunch][INFO] 2017-06-13 18:57:26,355: Added core node of type [rosout/rosout] in namespace [/]
[roslaunch.config][INFO] 2017-06-13 18:57:26,355: loading config file /home/ngcneuro/ca_ws/src/test_machine/launch/talker.launch
[roslaunch][INFO] 2017-06-13 18:57:26,357: Added node of type [beginner_tutorials/talker.py] in namespace [/]
[roslaunch][INFO] 2017-06-13 18:57:26,357: ... selected machine [robot] for node of type [beginner_tutorials/talker.py]
[roslaunch.pmon][INFO] 2017-06-13 18:57:26,370: start_process_monitor: creating ProcessMonitor
[roslaunch.pmon][INFO] 2017-06-13 18:57:26,371: created process monitor <ProcessMonitor(ProcessMonitor-1, initial daemon)>
[roslaunch.pmon][INFO] 2017-06-13 18:57:26,371: start_process_monitor: ProcessMonitor started
[roslaunch.parent][INFO] 2017-06-13 18:57:26,371: starting parent XML-RPC server
[roslaunch.server][INFO] 2017-06-13 18:57:26,371: starting roslaunch XML-RPC server
[roslaunch.server][INFO] 2017-06-13 18:57:26,372: waiting for roslaunch XML-RPC server to initialize
[xmlrpc][INFO] 2017-06-13 18:57:26,372: XML-RPC server binding to 0.0.0.0:0
[xmlrpc][INFO] 2017-06-13 18:57:26,373: Started XML-RPC server [http://192.168.1.103:59087/]
[xmlrpc][INFO] 2017-06-13 18:57:26,373: xml rpc node: starting XML-RPC server
[roslaunch][INFO] 2017-06-13 18:57:26,385: started roslaunch server http://192.168.1.103:59087/
[roslaunch.parent][INFO] 2017-06-13 18:57:26,385: ... parent XML-RPC server started
[roslaunch.remote][INFO] 2017-06-13 18:57:26,386: remote[red2-0] starting roslaunch
[roslaunch][INFO] 2017-06-13 18:57:26,386: remote[red2-0] starting roslaunch
[roslaunch][INFO] 2017-06-13 18:57:26,386: remote[red2-0]: creating ssh connection to red2:22, user[ngcneuro]
[roslaunch.remoteprocess][INFO] 2017-06-13 18:57:26,387: remote[red2-0]: invoking with ssh exec args [/opt/ros/indigo/env.sh roslaunch -c red2-0 -u http://192.168.1.103:59087/ --run_id 7ce15492-50a4-11e7-8d3e-40167e358fbd]
[paramiko.transport][INFO] 2017-06-13 18:57:26,428: Connected (version 2.0, client OpenSSH_6.6.1p1)
[paramiko.transport][INFO] 2017-06-13 18:57:26,555: Authentication (publickey) successful!
[roslaunch][INFO] 2017-06-13 18:57:26,574: launching remote roslaunch child with command: [env ROS_MASTER_URI=http://192.168.1.103:11311 /opt/ros/indigo/env.sh roslaunch -c red2-0 -u http://192.168.1.103:59087/ --run_id 7ce15492-50a4-11e7-8d3e-40167e358fbd]
[paramiko.transport][INFO] 2017-06-13 18:57:26,674: Secsh channel 1 opened.
[roslaunch][INFO] 2017-06-13 18:57:26,678: remote[red2-0]: ssh connection created
[roslaunch.pmon][INFO] 2017-06-13 18:57:26,679: ProcessMonitor.register[red2-0]
[roslaunch.pmon][INFO] 2017-06-13 18:57:26,679: ProcessMonitor.register[red2-0] complete
[roslaunch.server][INFO] 2017-06-13 18:57:27,177: child [red2-0] registered with server, uri[http://robot:39508/]
[roslaunch][INFO] 2017-06-13 18:57:27,181: master.is_running[http://192.168.1.103:11311]
[roslaunch][INFO] 2017-06-13 18:57:27,184: master.is_running[http://192.168.1.103:11311]
[roslaunch][INFO] 2017-06-13 18:57:27,186: ROS_MASTER_URI=http://192.168.1.103:11311
[roslaunch][INFO] 2017-06-13 18:57:27,190: setting /roslaunch/uris/host_192_168_1_103__59087' to http://192.168.1.103:59087/
[roslaunch][INFO] 2017-06-13 18:57:27,195: load_parameters starting ...
[roslaunch][INFO] 2017-06-13 18:57:27,199: ... load_parameters complete
[roslaunch][INFO] 2017-06-13 18:57:27,200: launch_nodes: launching local nodes ...
[roslaunch][INFO] 2017-06-13 18:57:27,200: launch_nodes: launching remote nodes ...
[roslaunch.pmon][INFO] 2017-06-13 18:59:30,777: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, started daemon 139629411092224)>
[roslaunch.pmon][INFO] 2017-06-13 18:59:30,799: ProcessMonitor._post_run <ProcessMonitor(ProcessMonitor-1, started daemon 139629411092224)>
[roslaunch.pmon][INFO] 2017-06-13 18:59:30,799: ProcessMonitor._post_run <ProcessMonitor(ProcessMonitor-1, started daemon 139629411092224)>: remaining procs are [<roslaunch.remoteprocess.SSHChildROSLaunchProcess object at 0x7efe01b43850>]
[roslaunch.pmon][INFO] 2017-06-13 18:59:30,800: ProcessMonitor exit: killing red2-0
[roslaunch][INFO] 2017-06-13 18:59:30,800: [red2-0] killing on exit
[roslaunch.pmon][ERROR] 2017-06-13 18:59:50,778: shutdown_process_monitor: ProcessMonitor shutdown failed!
[roslaunch][ERROR] 2017-06-13 19:00:05,826: error launching on [red2-0, uri http://robot:39508/]: Interrupted system call
[roslaunch][ERROR] 2017-06-13 19:00:05,827: Launch of the following nodes most likely failed: beginner_tutorials/talker.py
[roslaunch][INFO] 2017-06-13 19:00:05,827: ... launch_nodes complete
[roslaunch.pmon][INFO] 2017-06-13 19:00:05,827: registrations completed <ProcessMonitor(ProcessMonitor-1, started daemon 139629411092224)>
[roslaunch.parent][INFO] 2017-06-13 19:00:05,827: ... roslaunch parent running, waiting for process exit
[roslaunch][INFO] 2017-06-13 19:00:05,828: spin
[roslaunch][ERROR] 2017-06-13 19:03:45,303: remote[red2-0]: unable to contact [red2] to shutdown remote processes!
[roslaunch.remoteprocess][INFO] 2017-06-13 19:03:45,303: remote[red2-0]: closing ssh connection
[roslaunch.remoteprocess][INFO] 2017-06-13 19:03:45,303: remote[red2-0]: ssh connection closed
[roslaunch.pmon][INFO] 2017-06-13 19:03:45,304: ProcessMonitor exit: cleaning up data structures and signals
[roslaunch.pmon][INFO] 2017-06-13 19:03:45,304: ProcessMonitor exit: pmon has shutdown
[roslaunch][INFO] 2017-06-13 19:03:45,368: process monitor is done spinning, initiating full shutdown
[roslaunch][INFO] 2017-06-13 19:03:45,368: runner.stop()
[roslaunch][INFO] 2017-06-13 19:03:45,368: shutting down processing monitor...
[roslaunch][INFO] 2017-06-13 19:03:45,368: shutting down processing monitor <ProcessMonitor(ProcessMonitor-1, stopped daemon 139629411092224)>
[roslaunch.pmon][INFO] 2017-06-13 19:03:45,368: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, stopped daemon 139629411092224)>
[roslaunch][INFO] 2017-06-13 19:03:45,369: ... shutting down processing monitor complete
[roslaunch][INFO] 2017-06-13 19:03:45,369: done
[roslaunch.pmon][INFO] 2017-06-13 19:03:45,369: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, stopped daemon 139629411092224)>
[rospy.core][INFO] 2017-06-13 19:03:45,369: signal_shutdown [atexit]
Contents of the /etc/hosts file
127.0.0.1   localhost
127.0.1.1   NGNeuromorphic1
192.168.1.175   red1
192.168.1.212   red2
192.168.1.208   yellow
Originally posted by jayess on ROS Answers with karma: 6155 on 2017-06-13
Your ssh connection is connecting.
I believe that your problem is that your robot's hostname is 'robot' and that is not resolvable on the robot.
[roslaunch][ERROR] 2017-06-13 16:09:14,455: error launching on [address-0, uri http://robot:47383/]: No route to host
[roslaunch][ERROR] 2017-06-13 16:09:14,456: Launch of the following nodes most likely failed: beginner_tutorials/talker.py
When you say that you checked that you could ping each other. Did you check that you can ping yourself?
ping `hostname`
You can create a custom env file on the robot that sets things like ROS_HOSTNAME as well as sourcing the setup.bash. Or you can resolve the hostname resolution.
Originally posted by tfoote with karma: 58457 on 2017-06-13
Comment by jayess on 2017-06-13:
I've tried the hostname with a number of different names (red, yellow, etc.) along with different names for the address and user and have had the exact same results. I can also ping myself as well.
Comment by tfoote on 2017-06-13:
Can you explain what you mean by red and yellow? Can you provide a non-sanitized output? One of the machines cannot ping itself. And remember that when you ssh like this you don't get your ~/.bashrc.
ssh user@address ping \`hostname\`
ssh user@address ping robot
red and yellow are just names I have in my hosts file that I use to map to IP addresses within my network (based on the color of the robot). I was able to ping back and forth before so I never tried what you suggested. I pinged myself as you suggested and I get connect: Network is unreachable
Disregard the last comment. I had a misspelling in my command. I can ping myself without any problems.
Please provide the actual outputs from the commands you run with all the variations. Without that I can't do much to help you. You can edit your question to add more details. Share what are your hostnames, what's in /etc/hosts? What are the parameters your setting?Otherwise I can't help you debug.
Thanks for the update. As you can see the error is that it's still trying to contact robot You mention that you're setting ROS_IP, but you're using the stock indigo/env.sh You either need to change the hostname to or create a custom env script which will set the ROS_IP on the remote machine.
Comment by jayess on 2017-06-14:
Thank you very much for patiently walking me through all of this, it's now working. I did what you said: created a script to set the ROS_IP and ROS_MASTER_URI on the remote machine and sources the devel/setup.bash script.
Funny thing that's happening now is that after I stop the launch file (using Ctrl-C ) I can see that the nodes are still running by using rosnode list and I can't start up another roscore/master as it says that one is still running despite me not seeing one running in my terminal.
I also used this as extra resource to help get everything running.
