I am using a stereo camera set up which I need to recalibrate every time I want to use it. Is there anyway to save the best camera calibraiton parameters I got and just reuse them?
It would probably only work under the assumption that the camera's do not change in orientation with respect to each other, which is fairly trivial to do.
Originally posted by Sood on ROS Answers with karma: 20 on 2016-04-10
Comment by ahendrix on 2016-04-10:
Most of the ROS camera drivers already have functionality for storing the camera calibration on disk or on the camera, and reloading it at startup. Which camera driver are you using?
Comment by Sood on 2016-04-10:
The usb_cam driver.
