Hi all,
I'm trying to perform a calibration of a stereo usb camera using the usb_cam drivers. I am following the proper tutorial on the ROS wiki page (http://wiki.ros.org/camera_calibration/Tutorials/StereoCalibration).
My stereo camera is publishing left and right images over ROS (/image_raw), I can run the calibration node and I'm able to perform the acquisitions of the samples. When I push the "Calibrate" botton, not so long after it appears this error:
File "/opt/ros/indigo/lib/camera_calibration/cameracalibrator.py", line 244, in on_mouse self.c.do_calibration()
File "/opt/ros/indigo/lib/python2.7/dist-packages/camera_calibration/calibrator.py", line 1052, in do_calibration self.cal_fromcorners(self.good_corners)
File "/opt/ros/indigo/lib/python2.7/dist-packages/camera_calibration/calibrator.py", line 855, in cal_fromcorners flags = flags)
SystemError: new style getargs format but argument is not a tuple
The roswtf command returns no errors or warnings.
I'm using ROS Indigo running on Ubuntu 14.04 and I just started using the ros framework so I'm not an expert at all. The cameras I'm using are two ODROID USB-CAM 720P. Can you please help me to figure out how to solve this isssue?
Greetings.
Originally posted by I-man on ROS Answers with karma: 3 on 2015-07-08
Comment by Miquel Massot on 2015-07-09:
Hi! Make sure you are using the correct git branch, in case you compiled usb_cam repository from source.
Comment by I-man on 2015-07-09:
Thanks for your answer. The git branch I'm using is correct. For the installation of usb_cam I followed the steps described in http://answers.ros.org/question/197651/how-to-install-a-driver-like-usb_cam/.
By the way I can perform the (mono) camera calibration successfully. What's wrong?
Comment by Miquel Massot on 2015-07-13:
It looks like your opencv version is expecting a different set of arguments. Which version of OpenCV are you using? 2.4.11 is working correctly in my system. Are you on a newer version?
Comment by I-man on 2015-07-13:
Yes. the command pkg-config --modversion opencv returns 3.0.0. Should I use a previous version of OpenCV?
Hi!
You should install a compatible OpenCV version, such as 2.4.11. That error is telling you that the code is not compatible, as the API has changed.
Originally posted by Miquel Massot with karma: 1471 on 2015-07-14
Comment by I-man on 2015-08-16:
Thank you so much. As you suggested, I installed OpenCV 2.4.11 and it works!
Comment by Mudassir Khan on 2016-01-16:
I updated my openCV to 2.4.11 but still getting the same error. Any idea why ?
