Hi everyone,
i just bought a minoru 3d webcam to try using it as a low cost RGBD sensor, i'm working in ros indigo, i tried calibrationg the camera with the cameracalibrator.py util, the problem is that no matter how much frames i take the extrinsic calibration always fail because with the driver i was using there is too much lag between the frames of the two channels ( the camera is not synchronized ).
I tried several other drivers and the best so far ( the one that gives the best visual results in terms of lag ) seems the "usb_cam" driver. But if i use this driver the cameracalibrator.py node can't start i think this problem is related to the "set_camera_info" service as described in this link:
http://www.iheartrobotics.com/2010/05/testing-ros-usb-camera-drivers.html
The fix they suggest in the python code is already present in my version but still it doesn't work. I don't need that service, since i just need to get calibration matrices i can set manually the calibration files. What can i do? Thank you all in advance!
EDIT: Here is my launch file:
<launch>
<node name="left_camera" pkg="usb_cam" type="usb_cam_node" output="screen" >
<param name="video_device" value="/dev/video1" />
<param name="image_width" value="320" />
<param name="image_height" value="240" />
<param name="pixel_format" value="yuyv" />
<param name="camera_frame_id" value="usb_cam" />
<param name="io_method" value="mmap"/>
</node>
<node name="right_camera" pkg="usb_cam" type="usb_cam_node" output="screen" >
<param name="video_device" value="/dev/video2" />
</node>
</launch>
And this is the command i use to launch the camera calibrator:
rosrun camera_calibration cameracalibrator.py --size 9x6 --square 0.011 right:=/right_camera/image_raw left:=/left_camera/image_raw right_camera:=/right_camera left_camera:=/left_camera --no-service-check
And when i do so, simply nothing happens, no errors, no crashes. Maybe it keeps waiting for something?
This is the output of the rostopic list command:
/left_camera/camera_info /left_camera/image_raw /left_camera/image_raw/compressed /left_camera/image_raw/compressed/parameter_descriptions /left_camera/image_raw/compressed/parameter_updates /left_camera/image_raw/compressedDepth /left_camera/image_raw/compressedDepth/parameter_descriptions /left_camera/image_raw/compressedDepth/parameter_updates /left_camera/image_raw/theora /left_camera/image_raw/theora/parameter_descriptions /left_camera/image_raw/theora/parameter_updates /right_camera/camera_info /right_camera/image_raw /right_camera/image_raw/compressed /right_camera/image_raw/compressed/parameter_descriptions /right_camera/image_raw/compressed/parameter_updates /right_camera/image_raw/compressedDepth /right_camera/image_raw/compressedDepth/parameter_descriptions /right_camera/image_raw/compressedDepth/parameter_updates /right_camera/image_raw/theora /right_camera/image_raw/theora/parameter_descriptions /right_camera/image_raw/theora/parameter_updates /rosout /rosout_agg
EDIT2:
I've edited my launch file to use uvc_camera:
<launch>
<node pkg="uvc_camera" type="uvc_stereo_node" name="uvc_camera_stereo">
<param name="width" type="int" value="640" />
<param name="height" type="int" value="480" />
<param name="fps" type="int" value="20" />
<param name="frame" type="string" value="minoru" />
<!-- other supported params: auto_exposure, exposure_absolute, brightness, power_line_frequency -->
<param name="left/device" type="string" value="/dev/video1" />
<param name="right/device" type="string" value="/dev/video2" />
<param name="left/camera_info_url" type="string" value="file://$(find uvc_camera)/example-left.yaml" />
<param name="right/camera_info_url" type="string" value="file://$(find uvc_camera)/example-right.yaml" />
</node>
</launch>
Now the cameracalibrator starts properly, but i can see on the calibration window that the frames are still visually unsynchronized (i.e. if i blink i don't see this happening simultaneously in the two visualization windows ) I've also tried different resolutions and framerates.
I also added the flag --approximate=0.01
up to 0.05 ( it crashes at 0.1 )`
Originally posted by radisc on ROS Answers with karma: 61 on 2014-10-16
Comment by ahendrix on 2014-10-16:
Please edit your question to include a copy and paste of the exact command and the exact error message you get when starting the camera calibration.
