Hi,
I have a LIDAR connected to an AR drone, with drivers running on the drone to read the laser data, and send it to my ros master computer using netcat. I have written a ros driver in python that listens to the network and reads the incoming laser data, creates a LaserScan message, populates all the fields and then publishes this to /scan.
I can see /scan in rostopic list, and can see populated messages in rostopic echo /scan. However when I run my launch file which runs hector_mapping, no map is created. I know the launch file works as I have tested it with the LIDAR connected directly to the master computer using the official drivers and it builds a map fine.
So I think there must be a problem when I populate the LaserScan message and publish it. I have included one of my populated messages below, can anyone see anything wrong with it or suggest something else which I can try? I have noticed the seq fields in the header are always 0 but have read I shouldn't set that myself and leave ros to deal with it.
Node: /laserlistener
Time: 21:56:49.521363019 (2016-04-05)
Severity: Info
Published Topics: /rosout, /scan
header:
  seq: 0
  stamp:
    secs: 1459889809
    nsecs: 520699977
  frame_id: laser
angle_min: 3.14159265359
angle_max: -3.14159265359
angle_increment: 0.0174532925199
time_increment: 0.000515921866295
scan_time: 0.18521595
range_min: 0.15
range_max: 6
ranges: [0.0, 0.0, 1274.25,  ... ] omitted as lots of numbers, all look correct though
intensities: [ ... ] ditto
The angle_min and angle_max fields are meant to be like that (at least that is what the official driver spits out) I have also tried 0 to 2*pi
Launch file:
<launch>
<node pkg="tf" type="static_transform_publisher" name="map2odom" args="0 0 0 0 0 0 map odom 100" />
<node pkg="tf" type="static_transform_publisher" name="odom2base_frame" args="0 0 0 0 0 0 odom base_frame 100" />
<node pkg="tf" type="static_transform_publisher" name="base_frame2base_footprint" args="0 0 0 0 0 0 base_frame base_footprint 100" />
<node pkg="tf" type="static_transform_publisher" name="base_footprint2base_stabalized" args="0 0 0 0 0 0 base_footprint base_stabalized 100" />
<node pkg="tf" type="static_transform_publisher" name="base_stabalized2base_link" args="0 0 0 0 0 0 base_stabalized base_link 100" />
<node pkg="tf" type="static_transform_publisher" name="base_link2laser" args="0 0 0 0 0 0 base_link laser 100" />
<node pkg="tf" type="static_transform_publisher" name="map2scanmatcher_frame" args="0 0 0 0 0 0 map scanmatcher_frame 100" />
<include file="$(find hector_slam_launch)/launch/tutorial.launch"/>
<param name="use_sim_time" value="false" />
<param name="hector_mapping/pub_map_odom_transform" value="false"/>
<!-- Map size / start point -->
<param name="hector_mapping/map_resolution" value="0.050"/>
<param name="hector_mapping/map_size" value="2048"/>
<param name="hector_mapping/map_start_x" value="0.5"/>
<param name="hector_mapping/map_start_y" value="0.5" />
<param name="hector_mapping/map_multi_res_levels" value="5" />
<!-- Map update parameters -->
<param name="hector_mapping/update_factor_free" value="0.4"/>
<param name="hector_mapping/update_factor_occupied" value="0.9" />
<param name="hector_mapping/map_update_distance_thresh" value="0.01"/>
<param name="hector_mapping/map_update_angle_thresh" value="0.06" />
<param name="hector_mapping/laser_z_min_value" value = "-1.0" />
<param name="hector_mapping/laser_z_max_value" value = "1.0" />
<param name="hector_mapping/laser_min_dist" value="0.4" />
<param name="hector_mapping/laser_max_dist" value="4.0" />
<param name="hector_trajectory_server/trajectory_update_rate" value="4" />
<param name="hector_trajectory_server/trajectory_publish_rate" value="4" />
Publishing node:
#!/usr/bin/env python
import roslib; roslib.load_manifest('laserdrone');
import rospy; import math; import tf; from sensor_msgs.msg import LaserScan;
import socket; import numpy as np; import time; import sys;
if name == 'main': rospy.init_node('laserlistener');
pub = rospy.Publisher("scan", LaserScan, queue_size=10);
rate = rospy.Rate(10);
host = '';
port = 44444;
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM);
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1);
sock.bind((host, port));
sock.settimeout(15);
sock.setblocking(1);
sock.listen(0);
try:
    print "Waiting for incoming data for 15 seconds"
    request, addr = sock.accept();
except:
    print "timed out"
    sys.exit(0);
print "Connected"
angs = [];
dists = [];
Qs = [];
results = []
oldang = -1;
lastTime = rospy.Time.now();
    data = request.recv(10);
    while (data.find("\n")==-1):
        data += request.recv(1);
    #print data;
    try:
        line = data.split(","); #90.0, 1000.45, 12
        if len(line) != 3:
            continue;
        ang = float(line[0].strip());
        dist = float(line[1].strip());
        Q = float(line[2].strip());
        angs.append(ang);
        dists.append(dist);
        Qs.append(Q);
        if(ang < oldang):
            #publish here
            print "Publishing now";
            thisTime = rospy.Time.now();
            duration = (thisTime - lastTime).to_sec();
            lastTime = thisTime;
            print thisTime.secs, thisTime.nsecs, duration;
            # print thisTime, lastTime, thisTime-lastTime, thisTime.to_sec();
            lasermsg = LaserScan();
            lasermsg.header.stamp = lastTime;
            lasermsg.header.frame_id = "laser";
            lasermsg.scan_time = duration;
            lasermsg.time_increment = duration / 359;
            lasermsg.angle_min = math.pi;
            lasermsg.angle_max = -math.pi;
            lasermsg.angle_increment = math.pi / 180;
            lasermsg.range_min = 0.15;
            lasermsg.range_max = 6;
            lasermsg.ranges = dists;
            lasermsg.intensities = Qs;
            rospy.loginfo(lasermsg);
            pub.publish(lasermsg);
            angs = [];
            dists = [];
            Qs = [];
        oldang = ang;
    except KeyboardInterrupt:
        raise
    except:
        print "err, data:",data, ", ", sys.exc_info()[0];
rate.sleep();
Many thanks
Originally posted by andythepandy93 on ROS Answers with karma: 55 on 2016-04-05
Comment by YingHua on 2016-04-05:
Could you also upload your launch file? I guess it may cause by launch file connect.
Comment by andythepandy93 on 2016-04-06:
Knew I'd forgotten something! Added launch file and he publishing node
Comment by DavidN on 2016-04-06:
Can you visualize the scan via rviz? Also, I saw you set the max range to be 6m but i also saw the laser scan data 1274.25. Are you sure all the laser scans have correct distances. In Hector slam, the scan will be filtered by the laser_max_dist set in launch file (4m in your case)
Comment by andythepandy93 on 2016-04-07:
I cannot visualise with rviz, it counts up the messages coming in so is definitely receiving them. Very true, when I run it with the actual drivers all the numbers are much smaller. I will check the code and post back
Yes that was it! The numbers were in millimetres instead of meters. Thanks for the pointer
Don't know how to mark this as answered either as these are only comments to the original question
Comment by DavidN on 2016-04-07:
That s great. You can write your own answer of how you fixed it in the answer session.
Comment by andythepandy93 on 2016-04-08:
I've added it, but says I need >10 points to accept my own answer
Turns out the drivers I was using on the AR drone were giving out millimetres instead of the meters that LaserScan is expecting. After dividing the output by 1000, I get a map and pose as expected. Thank you to DavidN for pointing it out
Originally posted by andythepandy93 with karma: 55 on 2016-04-08
Comment by Icehawk101 on 2016-04-08:
You now have 11 points and can answer your own question :P
Comment by andythepandy93 on 2016-04-09:
Ah nice, thanks
