Hello everyone, after a month of trying to solve some issues , I haven`t got any lucky. That is why I am turning to this forum to see if someone can help me with it . Here is my problem in context:
I have designed a robot in which I use a jetson nano, Arduino mMega 2560, IMU- MPU6050, Intel Realsense D435, T256, ydlidar X4 and ROS Melodic.
Problem 1
When I try to integrate the ros rtabmap package the figure shows how rviz represents the point cloud.
image description
I have tried to apply a transformation to the cameras to rotate the point cloud and display it correctly:
Position and orientation of the D435 camera within the URDF:
xyz = -0.047515, -0.0065262, 0.64317
rpy = -1.5708, 0, -1.5708
Position and orientation of the T265 camera within the URDF:
xyz = -0.035015, -0.0065262, 0.58873
rpy = 1.5708, 0, 1.5708
node pkg="tf" type="static_transform_publisher" name="camera_link_to_t265_link" args="-0.047515, -0.0065262, 0.64317 -1.5708, 0, -1.5708 /t265_link /odom/sample 100"
node pkg="tf" type="static_transform_publisher" name="camera_link_to_d435_link" args="-0.047515, -0.0065262, 0.64317 -1.5708, 0, -1.5708 /d435_link /color/image_raw 100"
Problem 2
When I try to do 2D navigation, ros returns these errors and warnings and I don't know how to fix it:
[ERROR] [1616447739.443209583]: The goal pose passed to this planner must be in the map frame.  It is instead in the base_link frame.
[ WARN] [1616447739.443272106]: Failed to transform the goal pose from base_link into the map frame: Lookup would require extrapolation into the future.  Requested time 1616447739.441912138 but the latest data is at time 1616447739.359707971, when looking up transform from frame [base_link] to frame [map]
[ERROR] [1616447739.443394782]: The goal pose passed to this planner must be in the map frame.  It is instead in the base_link frame.
[ERROR] [1616447739.443574767]: The goal pose passed to this planner must be in the map frame.  It is instead in the base_link frame.
Rqt Graph
Nodes Only
image description
Nodes Topics
image description
All Nodels
image description
Thank you for your help.
jarain78
Originally posted by jarain78 on ROS Answers with karma: 9 on 2021-03-22
Comment by njit on 2021-12-30:
Hi @jarin78, What types of motors and motor controller you used in your project?
For your first problem, you seem to have resolved it by adjusting the tf static_transform_publisher.
For the problem 2, the goal you are sending should be sent in map frame, you are sending it in base_link frame. Are you sending goals with RVIZ? make sure your global frame (in global options) is set to map.
Originally posted by matlabbe with karma: 6409 on 2021-05-02
