hello everyone
I'm using slam gmapping to produce a map, but I've noticed that the output Occupancy Grid Map(which is broadcast to topic /map) contains only -1,0 and 100 for unknown, free and occupied grids respectively.
I'm wondering is there a way to produce a map with other values say 0.05, 0.37, 0.52 etc. which represent the probability of the grid to be occupied? I've checked out the parameters available for gmapping but could not find a clue about this.If it's not available in gmapping, then how should I do this?
any help will be much appreciated, thank you all!
Originally posted by edmond320 on ROS Answers with karma: 61 on 2016-03-18
