Hi everyone,
I'm trying to build a map using SLAM(gmapping) and my own (virtual) robot which is equipped with a hokuyo LRF under Gazebo, i have looked around but could not find a tutorial on how to do this. for example
http://wiki.ros.org/robotino_navigation/Tutorials/Mapping%20with%20Robotino http://wiki.ros.org/turtlebot_navigation/Tutorials/Build%20a%20map%20with%20SLAM
these tutorials don't explain how to do it with a customized robot.
my question is how do i obtain the laser scan data and pass it to the corresponding listener? I've noticed in some tutorials it is published by a topic named /base_scan,which does not appear when i load the model into the Gazebo environment.
Any suggestions or help will be much appreciated. Thanks!
Originally posted by edmond320 on ROS Answers with karma: 61 on 2016-02-13
Comment by moshimojo on 2018-01-31:
Hello! I have the same problem a long time now. DId you find any solution to the problem? Thank you
buy the Book Programming Robots with ROS: A Practical Introduction to the Robot Operating System It hast an step by step tutorial and it easy to read.
Originally posted by duck-development with karma: 1999 on 2016-02-13
