I've try reinstall my ROS but after that when i reopen my terminal it will show me :
bash: /opt/ros/jade/setup.bash: No such file or directory
And also during the Environment setup step when i type in " source ~/.bashrc " it shows " bash: /opt/ros/jade/setup.bash: No such file or directory "
any one know how to solve this problem? thank yo
Originally posted by Zero on ROS Answers with karma: 104 on 2016-03-16
Comment by mgruhler on 2016-03-16:
Which ROS-Distro did you install? The title says hydro
, the question jade
. You cannot install them on the same system.
Also, if you tried reinstalling it and this file is not there, there has ben a problem with the reinstall. Where there any errors when you did sudo apt-get install ros-<XY>
Comment by Zero on 2016-03-16:
Sry, the title should be jage, is not hydro. and im installing indigo.
Comment by NEngelhard on 2016-03-16:
Then please edit the question.
