Dear Users;
I installed Ros Lunar distro before. After that I decided to switch to Kinetic. Therefore, I remove Lunar from the terminal, and then installed ROS Kinetic. However; I still have this problem: "bash: /opt/ros/lunar/setup.bash: No such file or directory"
I can not find where is this file. In the opt directory, there is no lunar, because I already deleted it. And I can't find that comment file to fix that source file that is reading that comment.
Any advice? Thanks in advance.
Originally posted by ercan_ros on ROS Answers with karma: 3 on 2017-12-26
Please see whether #q253480 helps.
Originally posted by gvdhoorn with karma: 86574 on 2017-12-26
Comment by ercan_ros on 2017-12-26:
Dear @gvdhoorn; Yes, I already searched before and I already seen that page. However, even though I tried what it was said there, it didn't fix the problem. Later I found this, and it fixed the problem: Dear @gvdhoorn, thank you for your response.
