I am trying to set the environment setup after installing the ROS full package using terminal. I get the following message: kadir@kadir:~$ echo "source /opt/ros/hydro/setup.bash" >> ~/.bashrc kadir@kadir:~$ source ~/.bashrc bash: /opt/ros/cturtle/setup.bash: No such file or directory
what am i doing wrong?
P.S beginner
Originally posted by Abdul on ROS Answers with karma: 27 on 2014-04-20
There is still an old entry to /opt/ros/cturtle/setup.bash in your ~/.bashrc. Just remove that line.
Originally posted by dornhege with karma: 31395 on 2014-04-20
Comment by Abdul on 2014-04-20:
must i remove the whole file or just the line in my setup.bash file? and if line which line?
Comment by dornhege on 2014-04-20:
No, just the line that contains cturtle.
